I'm searching for a source for the foam tape, 1" wide x about 1/8" thick, that is located between the side rail mouldings. The original foam tape I pulled off the the molding seemed to only have adhesive on one side (attached to the lower molding. Parts houses like NPD don't stock it, but recommend Scotch/3M 1" wide double sided adhesive foam tape. I think using double sided adhesive tape would make installation difficult. Anyone got a recommendations?
Thanks in advance..
Matt
