Brake caliper question
  • What inlet size is correct on the brake hose port
    of the calipers? 3/8 or 7/16? It currently has 7/16 dia
    inlets. I read that 65-66 used 3/8 and later years had 7/16.
  • 1965 and 1966 calipers are 3/8". 1967 calipers used the 7/16" lines. The 1967 calipers also have a "nub" cast into them at the top that protects the crossover tube that routes the fluid between the inner and outer halves of the caliper assembly.
