E-Brake Handle assembly
  • Can someone post or send a picture of the ebrake handle assembly where the piece that contacts the ribs on the handle shaft (this piece stops the shaft from going back in when you pull the handle out) mounts, with the small wire spring. Mine came off when I changed the cable. Thanks.
  • Hi Bo, one the emergency brake handle assembly, up close to the handle, is a small H looking metal piece that contacts the "ribs" in the ebrake shaft. That is what makes the clicking noise when you pull the handle out. The small H piece is held against the shaft with a wire spring. Mine came out when I replaced the cable, so now it does not click or lock in place when you pull the handle out. I can just call you if this does not make sense....Thanks.
