________________________________________
66 hipo engine for sale
Heads and block came from same engine!
6B23 heads done –hot tanked, magnafluxed for cracks, glass beaded to bare metal, epoxy primered, stainless steel valves, hardened exhaust seats, new comp cams springs, keepers, trued machined faces , stock rockers, sleds and jamb nuts
6C19 block , maganafluxed, deburred casting for dist oiling, bored to nearest oversized, align honed. Trued head surfaces , CAM BEARINGS INSTALLED !, oiling passage matched. Epoxy primered exterior. All holes retapped and cleaned , alignment dowels installed
Rebuilt beamed HP Rods, rebuilt Crank with new pilot bushing installed , new Pistons
New balancer, bolt and washer
Original Ford head bolts
Solid Lifter Hipo specification Cam and lifters and pushrods
Double roller Timing set , fuel pump eccentric, slinger
Premium Moly Rings and Bearings
Timing cover and water pump
Head Gaskets ,Intake, oilpan, timing cover water pump gaskets Felpro
Oilpump blueprinted with chrome moly pump , safety wired bolts and pickup
Balance rotating assembly
Blueprinted shortblock
Flywheel , fresh surface with correct bolts –safety wired
Clutch kit Mcleod premium plate/ disc , includes grade bolts drilled for safety wire
Paint - single stage urethane Blue
Stock steel original 289 Oilpan
Stock steel 289 valve covers
Cast Iron 4V Intake
Test run on our engine stand to check for leaks and oil pressure
Crated for shipping!
$9995 plus freight shipping!
Optional parts available with sale of engine, prices includes trade back on quoted stock parts.
Forged Stroker Rotating assembly $750
Original Cobra lettered S2MS part number intake restored $900
Lemans Carb new $995
Rechromed original air cleaner with new element and decals $500
Buddy Bar Cobra Covers restored originals $650
New concourse repo Cobra valve covers $210
Fomoco breather Cap and hose with correct clamps $50
NOS Shelby PCV valve and correct hose and clamps $100
Bellhousing and clutch fork/boot with block plate, correct #s $350
Alternator , brackets and bolts restored $ 300
Starter -restored C3OF with script $ 250
Tri-Y Headers - concourse jet coated $ 1100
Script fan Belt and Pulleys $ 100
Install your parts and run engine on stand $250
Stainless steel roller rockers, will require holes made in valve cover baffles $250
NOS Diamond FROST PLUGS (10) $50
Carbon Kevlar clutch disc $100
Blueprinted close ratio toploader and shifter $2500
Blueprinted Close ratio cast iron T10 and shifter $4500
Restoration of any parts supplied extra!
Check with us for individual Hipo and Shelby parts!
(920) 434 3645
