65 parts list
-65 /66 Shelby Goodies – original parts noted
-Cobra Lettered 6 bolt bellhousing – original . restored with correct boot , side hook fork, new block plate $2200
-6 Bolt Hipo Block, standard bore but needs 2 sleeves $1200
-6 Bolt Hipo block. Hot tanked, steelebrated, checked for cracks, epoxy primered exterior, rough bored to +30 , oiled and bagged, have one early 65 and one late 65 date coded $2000 crated FOB
-65 axle tube with correct override brackets $1500
-66 scalloped axle tube no brackets $1200
-65 GT350 drum to drum rear end, completely restored and concourse detailed! correct housing with override brackets, Hipo axles, 389 detroit locker . 5D date coded 3rd member housing. Machined bare bearing retainer, correct red oxide finishes and bare metal where necessary, Hipo pinion yolk, Hipo steel rebound plate with fine thread stud bumper, 49294/5 kelsey Hayes backing plates, kelsey Hayes drums, metallic DS11 velvet Touch 2 ½ inch shoes, small bleeder brake cylinders, correct KH e brake hardware, oem finish steel brake line, new flex line breather, concours correct - inside and out! ready to bolt in! $4995 crated and ready to ship! FOB Green Bay
-65/66 Hipo Axles – maganafluxed, machine trued face, phosphate studs, new premium bearings ready to install $550
-65/66 3rd member – 3.89 Detroit Locker , early 65 date coded Fresh setup and detail $1200
NOS Control arms- show detailed , includes (2) uppers and (2) lowers, ready to install! $2000
65/66 Coil spring seat – restored using rust free western original saddles $300 pr.
-65/66 Brake drums – fresh concourse restored $600 pr.
-65/66 Rear brake backing plates, restored correct KH #s Have a pair of early 65s and late 66/67 plates available from Arizona –all restored $500 pr.
-65/66 driveshaft – complete with correct slip yolk, bare metal tube, stamped weights, proper striping $950
-66 T10B cast iron close ratio, late Gt350 , totally restored , racing synchros, premium bearings , $3500
-65/66 T 10 M alloy transmission , brand new alloy main case and tailshaft housing, racing synchros, premium bearings, brand new nickel close ratio gears 2.36 ratio, Includes concourse restored shifter assembly, ready to install $7500
-65 early chromed handle shifter assembly, complete with restored-reshimmed, replated control box, bare metal rods, cad plated levers , reshimmed, complete ready to install! $750
-66 late shifter assembly $695-Override bars m 1 ends $250 pr.
-Override rebound bumper relocation Bracket $95 pr.
-Axle limiting cable kit with forged eyebolts $50 NOS Short Forged seat belt eyebolts $25 EACH
-Ray Brown seat belts, restored correct short floor hooks $1100 (2) beltsImpact seat belts, correct later long hook versions, restored $1100 (2) belts
-T10M new limited production aluminum main case $1500
-T10M new limited production aluminum tailshaft housing $1500
-Hipo GT350 R Model full race damper, fully degreed $800
-Hipo balancer new $250
-Hipo Fan original restored $750
-Used original steel framed Hood – needs major redo $500
-GT350 script for 65 fenders $50 DEAD ON!
-Fastback door window frames, polished, ready for glass $500 pr. Or with new dated script glass installed $900 pr.
-R model rear window kits , plexiglass, frames and mounting hardware $
-Repro R –Model rollbar $300
-Front Brake Calipers - concourse correct plated – machined bare metal , all new seals, pistons, transfer tubes $550 pr.
-Rear segmented 2 ½ INCH brake shoes – full metallic DS11 compound $250 set
-Tri-Y Headers – as close to NOS as you can get. A little background history on our headers. We tried all the repo headers out there, you know, the ones that go for between $99 and $179. Talk about garbage. This was the type of part that gave reproduction parts the typical bad rap or what Bob Perkins calls Gyppo parts . I finally got fed up and took my original set of headers off my 65 GT350 and had a real custom old school header fabricator make them like they did in 1965. They made a steel fixture to make sure each set is replicated the same way. I had the flanges made to the correct thickness and beveled edge and also had the 3 bolt collector flanges made to the correct shape. The tubes are mandrel bent to original specs using the same gauge steel and miter cut to the original shape to weld . They are welded the same way they did it on the original set. Once completed on the jig , each bolt hole is clearanced to make sure you can use a 6 point box wrench on each header bolt. Lastly they are shot blasted to get rid of any imperfections and jet coated a semi gloss satin finished. These are extremely labor intensive parts to make with about 2 days labor invested in each set. The guy that makes them can only supply about 15 sets a year as they are such a small order and he makes them when he has time. They trickle in about 2 sets every other month so It’s rare when I have an extra set in stock. ANY OTHER QUESTIONS GIVE US A CALL 920 434 3645
-Front Disc brake Spindles – concourse detailed $400 Pr.
-Front disc brake corners- all assembled! All concourse restored! Includes spindle, plant style dog tooth rotors, 65/66 style backing plate, all correct mounting bolts, brake calipers plated outer half, caliper mounts, metallic pads, pad retainers, bearings seals. Grease and grease cap – All original restored Ford parts except DS11 pads. Ready to install all in one piece! $2000 pr. right and left!
-Metallic brake pads $60 set
-65 Carb to pump line $15
- 66 carb to pump line for 715 $25 brand new part!
-66/67 carb to fuel pump brass 1 inch hex adaptor $40
-65 Oil line block adaptor $60
-65 Braided oil line $75
-Hipo 289/Boss 302 replacement premium McLeod clutch kit, Long pressure plate, Carbon Kevlar disc. Premium throwout bearing $400
-NOS PCV Valve $75
-65 Hipo engine mounts – complete set restored with new intermediate plates $1000
-65 hipo mounts intermediate plates with stud $195 pr.
-65 Trunk mount battery kit $350
-Email me for best quality reproduction fiberglass parts !
-American Racing Torquethrust D 15 x 7 wheels, fully polished outer rim $850 set/4
-Cragar wheel center caps – correct white painted and black race track $400 set
-Fastback door window frames, polished, ready for glass $400 pr. Or with new dated script glass installed $850 pr.
-Original 10 spoke wheel, fully restored , looks better than NOS $1000 bare or mounted with brand new correct Blue Streak $1395 shipped.
-Late 65/early 66 Steel framed hood - needs attention $500
-R model rear window kits , plexiglass, frames and mounting hardware $750
-Overriderelocation brackets $95
-Overrider axle brackets – concours type welded like originals with same gauge steel $85 pr.
-Override bars M1 ends $250 pr.
-Koni Lower shock bell shaped rubber boot $60 pr. Ready late March
-Koni Shock bolts new - $60 set, ready late Feb
-65/66 driveshaft – complete with correct slip yolk, bare metal tube, stamped weights, proper striping and date coding . $950
-65 Hipo heads C5OE 4H3 dated Ported, swirl polished stainless valves, correct early large nut studs, comp cams springs retainers, keepers. Fresh face on exhaust and block side, ready to install! $2200
-65 Hipo Heads C5OE 4J16 Bone stock unported! Maganafluxed . bead blasted to bare metal , epoxy coated exterior. Oiled $1500 bare! Or $2000 fresh same as above!
-66 Hipo Heads C5OE 6B Bone stock unported ! $1500 bare! Same deal as above!
- NOS 289 fuel pump camshaft eccentric $40
-65 HCC-AX Steering box 5A14 Tag restored bare metal machine surfaces, machined re-profiled worm gear. New bearings seals color coded $550
-66 HCC-AX Steering Box see above Choice of 5H23 or 6C29 $550
-Cragar /66 10 spoke lugs $100 set
-Buddy Bar Valve covers – completely restored $600 pr.
65/66 Alternator restored old style $250
R Model Tall breather valve covers $400 correct zinc plated with Cobra decals! with new black caps and concourse Fomoco decals $425
289 Hipo air cleaner decals – concours quality limited run made using NOS for camera ready artwork, correct colors, correct C5 part number, clear overlay like originals, also have correct straight autolite decal for 65 and curved for 66 $40 set!
(920) 434 3645 jim@shelbyparts.com
