Hi guys
I would need that block wich is attatched on the 65 Hipo rearend
where the brakehose goes to.
When possible complete with the metal strap and the vent piece.
Thanks Jerry
Hi guys
Thanks Jerry
Jerry, These are reproduced very nicely I might add.....the vent fitting is independent of the brake hose/fitting/bracket.
The vent fitting threads into the axle housing and the brake line/block slips over it.
The pn for it in the VA Mustang catalog shows BK-112
I asked this question sometime back about where you can buy replacement accurate axles hose and noone added any comments?
You thing the repro is ok?
I think i got a catalog somewhere i´ll check right away
thanks!
But anyway if someone has a original would be best!
Thanks Jerry
http://npd.dirxion.com/WebProject.asp?BookCode=mtg09flx#
Isn't this it in the NPD catalog p60? PN 2282-1B @$49.95
Pretty sure AMK also has the correct tubular bolt/vent tube which attaches it/
I sincerily believe that the repro that VA Mustang sells for $38.95 is very accurate, and they also have the vent fitting.
RPM: Sorry, I didn't see your post on this....
