Wanted for 12-64 San Jose' fastback
  • Need the following for 12-64 build date San Jose’ HiPo fastback
    FoMoCo coil, HiPo Alt Belt C5OE
    Standard harness, V8 with alternator and idiot lights (not gauges)
    C5ZZ-14289-G Gauge Feed
    C5ZZ-14290-C Headlamp Feed
    Original Front bumper, no date stamp or must end in a “4” (will re-chrome) C5ZZ17766A, 67A, C5ZZ17A975A, 76A Front bumper brackets (4 pieces)
    Any NOS parts, especially trim rubber, C5ZZ-63 Trunk Seal, - Must have C4 or C5 engineering #’s and part #.
    One Rear ¼ drain plug
    FoMoCo Voltage Regulator
    NOS C5ZZ-D tie rod ends
    One 1965-1966 NOS REAR TAIL LIGHT BODY. PART#C5ZZ-13434-B. (NOT the one with the plug already attached (13434-A). they aren’t right and cant be made right)
    Any NOS parts that are for 65 or good used - Black door panels (Early “Thin type, not the latter “puffy” style) & Black seat backs (have near perfect seat covers now) NOS carpet
    Rear Axle brake kit, single crimp version with correct stamping on bracket & C5ZZ part # (2282-D?)(& Sticker if possible) including rear brake line. Also need front disk brake hoses.
    C5ZZ-2454-A before 3/65 disc brake pedal pad (no provision for trim ring)
    Group 24 Tar-top or Yellow Script / yellow Caps Battery, standard posts, any condition.
    Negative cable. Defrost Heater Tubes & Cones. C4ZB17698C Mirror Bracket. Pair “Flat Top” hood bumpers. NOS Front window “runners” with clear plastic C522652-1538A & 39A) <left & right>
    Good rust free straight disc brake dust shields right and left - fit 65/66 only
    Good rust free coil spring guards right and left
    Thank you.
    Mike 516-356-2319
