Is the S7MS-9424A a reproduction intake manifold? I don't find a ford part number or any other identifers on the intake. Thanks
Cobra Intake
Does it have 4 round holes or 2 oval holes? If 4, then probably original.
Well, for sure on one side it had two holes as you can see where someone had removed the center, fairly nice job, but evident that someone had did some grinding. The other side appears smooth but I suppose it could have also had the center casting ground out.
I am not aware of any S7MS manifolds that were made in the aftermarket. If it is a Cobra lettered intake it is correct for a later production 67 shelby. The mods done to the carb mounting pad will effect the price a bit if you are trying to sell it.
