Used Hipo Rocker Arms and Push Rods
    • Official Post
    Here is an Ebay auction for a set of used rocker arms, nuts and push rods by Ebay member "acond classic american_auto_parts" with a Buy-It-Now of $349.00:
    This is a nice original Ford rocker arm, fulcrum and retaining nut and push rod set which is correct for all 1963 19641965 Ford and Mustang 260 and 289 and 289 HIPO engines equipped with the aluminum water pump ( These generally go from the start of 1963 model production to June of 1965).and also continued to be used on all 1966 and 1967 HIPO 289 engines. This is a good original Ford set with very little wear. Take a look at the photos to see just how nice it really is. You will receive 16 correct original rocker arms, 16 correct fulcrums, 16 correct original push rods, and 14 original rocker arm retaining nuts. All are correct original Ford parts. It is correct in every detail and also correct for the Shelby and HIPO 289. No repro import crap here!
    65 66 67 MUSTANG & HIPO 289 ROCKER ARM & PUSH ROD SET (64 PC) C20Z 6564 A ORIG | eBay
  • Here is an Ebay auction for a set of used rocker arms, nuts and push rods by Ebay member "acond classic american_auto_parts" with a Buy-It-Now of $349.00:
    This set of used rocker arms, nuts and push rods sold August 27, 2025 on Ebay for $349.00.
  • Here is an Ebay auction for a set of used rocker arms, nuts and push rods by Ebay member "acond classic american_auto_parts" with a Buy-It-Now of $289.00:
    This is a good used original Ford rocker arm, fulcrum and retaining nut and push rod set which is correct for all 1963 19641965 Ford and Mustang 260 and 289 and 289 HIPO engines equipped with the aluminum water pump ( These generally go from the start of 1963 model production to June of 1965).and also continued to be used on all 1966 and 1967 HIPO 289 engines. This is a good used original Ford set with some of the push rods and rocker arms having some wear. Take a look at the photos to see if they will suit your needs.. You will receive 16 correct original rocker arms, 16 correct fulcrums, 16 correct original push rods, and 14 original rocker arm retaining nuts. All are correct original Ford parts. It is correct in every detail and also correct for the Shelby and HIPO 289. No repro import crap here!
    This set of used rocker arms, nuts and push rods sold March 1, 2026 on Ebay for $289.00.
    • Official Post
    Here is an Ebay auction for a set of used rocker arms, nuts, push rods and springs by Ebay member "acond classic american_auto_parts" with a Buy-It-Now of $689.00:
    This is a good used original Ford rocker arm, fulcrums, and valve spring, and push rod set, which is correct for all1964 1965 1966 1967 Ford and Mustang and Shelby 289 HIPO. This is a good used original Ford set with very little wear on anything. The valve spring retainers are not correct HIPO, but are original Ford, and will work fine. All of the rest of the parts are original Ford HIPO parts. Take a look at the photos to see if they will suit your needs.. You will receive 16 correct original rocker arms, 14 correct fulcrums, 16 correct original push rods and 16 valve springs. All are correct original Ford parts. If you are building a HIPO, you already know how hard it is to assembly all of the correct original Ford parts such as these. No repro import crap here!
    65 66 67 MUSTANG HIPO &SHELBY 289 ROCKER ARM, PUSH ROD & SPRING SET C20Z 6564 A | eBay
