NOS C5ZZ 3A131 D M/S Inner Tie Rod End
  • Here is an Ebay auction for a pair of NOS C5ZZ 3A131 D 65/66 Mustang M/S inner tie rod ends by Ebay member "jollyroge" with a starting bid of $0.99:
    NOS 65-66 Mustang Shelby GT350 inner tie rod ends C5ZZ-1A131-D. Here is a pair of NOS inner tie rod ends for a 65-66 V-8 Mustang . These are the same for left and right on a manual steering car and are correct for the RH side of a power steering car. These are still in the 1960’a Ford boxes with the part number C5ZZ-1A131-D on it. These would be concours correct any early V-8 Mustang including 65-66 Shelby GT350’s. One of the first consumable things to get replaced on your classic Mustang in period. Essential for a concours type restoration and also very noticeable . Instead of cleaning up original parts that are worn beyond the normal life span here factory new inner tie rod ends to install. Long obsolete from Ford and difficult to find. If you need these for your restoration here they are. Winner pays for Priority Mail to the Lower 48 States. Good luck bidding !
    Inner tie rod ends C5ZZ-1A131-D | eBay
    This pair of NOS C5ZZ 3A131 D 65/66 Mustang M/S inner tie rod ends sold October 27, 2023 on Ebay for $321.56 with 74 bids from 9 bidders.
  • Here is an Ebay auction for an NOS C5ZZ 3A131 D 65/66 Mustang M/S inner tie rod end by Ebay member "jollyroge" with a starting bid of $0.99:
    NOS 65-66 Mustang Shelby GT350 inner tie rod end C5ZZ-1A131-D. Here is an NOS inner tie rod end for a 65-66 V-8 Mustang . This is the same for left and right on a manual steering car and are correct for the RH side of a power steering car. This is still in the 1960’a Ford box with the part number C5ZZ-1A131-D on it. This would be concours correct any early V-8 Mustang including 65-66 Shelby GT350’s. One of the first consumable things to get replaced on your classic Mustang in period. Essential for a concours type restoration and also very noticeable . Instead of cleaning up original parts that are worn beyond the normal life span here is a factory new inner tie rod end to install. Long obsolete from Ford and difficult to find. If you need one for your restoration here it is. Winner pays for Priority Mail to the Lower 48 States. Good luck bidding !
    https://www.ebay.com/itm/115972958447
    NOS 65-66 Mustang Shelby GT350 inner tie rod end C5ZZ-3A131-D. Here is an NOS inner tie rod end for a 65-66 V-8 Mustang . This is the same for left and right on a manual steering car and are correct for the RH side of a power steering car. This is still in the 1960’a Ford box with the part number C5ZZ-1A131-D on it. This would be concours correct any early V-8 Mustang including 65-66 Shelby GT350’s. One of the first consumable things to get replaced on your classic Mustang in period. Essential for a concours type restoration and also very noticeable . Instead of cleaning up original parts that are worn beyond the normal life span here is a factory new inner tie rod end to install. Long obsolete from Ford and difficult to find. If you need one for your restoration here it is. Winner pays for Priority Mail to the Lower 48 States. Good luck bidding !
    This NOS C5ZZ 3A131 D 65/66 Mustang M/S inner tie rod end sold November 18, 2023 on Ebay for $178.50 with 23 bids from 8 bidders.
