I collaged photos together so that the thread remains reasonably organized, not flooded with a ton of photos (I am aware though I have a lot of photos posted already).
I have created 3 separate listings/posts for the 3 intakes labeled and pics annotated "A", "B", and "C".
Would definitely be willing to meet semi locally to the Seattle area (Bellingham and Portland Oregon are about as far as I would like to travel).
Intake “C” – Rear Firing Pad, Angled A, OECO Stamp
This intake is earlier than my “A” and “B” intakes. This intake though has heli-coils installed in the 2 front thermostat mounting holes, but all other threads are good.
Corrosion is not quite as bad as my listed “B” intake, but does show corrosion mainly on the rear mounting surface and a little at the thermostat housing face. Intake had the front drivers side ear broken off at some point and was repaired. I took 2 pics with flash to show the inside of the water jacket at the ear, there is still a crack on the inside that I would recommend being welded up. Everything else is good on the intake.
Asking $750 $600 plus shipping due to repaired ear, corrosion and heli-coils
