Used HCC-AX Steering Gear Box Tag
  • Here is an Ebay auction for a used HCC-AX steering gear box tag by Ebay member "acond" with a Buy-It-Now of $98.00:
    This is a very nice all original Ford steering gearbox ID tag which is correct for all 1965 and 1966 Mustang cars equipped with the special handling package 16:1 steering gear which was used on non power steering GT cars, Shelbys and Hipo cars. It is correct for 8 cylinder manual steering cars. Good shape with no rust or damage.
    65 66 MUSTANG STEERING GEAR TAG HCC-AX ORIGINAL FORD M/S CORRECT 16:1 HIPO 289 | eBay
    This used HCC-AX steering gear box tag sold January 29, 2023 on Ebay for $98.00.
    • Official Post
    Here is an Ebay auction for a used HCC-AX steering gear box tag by Ebay member "stanger53" with a Buy-It-Now of $125.00:
    This is an original factory production HCC-AX Steering Box ID Tag that was mounted on 16:1 ratio 1965 & 1966 Mustangs with factory manual steering, which would be Shelby Mustangs, 289 HiPo factory Mustangs and Factory GT Mustangs with manual steering.
    Similar to the steering box used in power steering cars, the HCC-AX was a unique identification to indicate it came on performance Mustangs and had a slightly tighter input shaft bearing preload from standard boxes.
    The date code on this tag is 5F21C which indicates that it originally came on a 1965 year model Mustang and the box was assembled on June 21 on the 'C' shift.
    It would be correct for cars built a month or so earlier up to a week or so before the tag date.
    Sold only in USA
    HCC-AX Mustang Steering Box ID Tag -- Original 1965-1966 Shelby/GT/289HP | eBay
    • Official Post
    Here is an Ebay auction for a used HCC-AX steering gear box tag by Ebay member "MagMustangs" with a Buy-It-Now of $149.00:
    1966 Ford Mustang GT, Fastback, Coupe, Convertible, Shelby GT350. Original STEERING GEAR BOX I.D. TAG - 16:1 With Handling Package. This is an ORIGINAL FORD TAG. Stamped [ HCC AX and 5J14B ] Removed from a 66 Mustang GT Convertible.
    1966 Mustang GT Fastback Coupe Conv Shelby ORIG HCC AX M/S P/S STEERING BOX TAG | eBay
    • Official Post
    1966 Ford Mustang GT, Fastback, Coupe, Convertible, Shelby GT350. Original STEERING GEAR BOX I.D. TAG - 16:1 With Handling Package. This is an ORIGINAL FORD TAG. Stamped [ HCC AX and 6G01B ] Removed from a 66 Mustang GT Fastback.
    • Official Post
    This used HCC-AX steering gear box tag sold July 9, 2024 on Ebay for $125.00.
  • Here is an Ebay auction for a used HCC-AX steering gear box tag by Ebay member "MagMustangs" with a Buy-It-Now of $149.00:
    This used HCC-AX steering gear box tag sold February 9, 2025 on Ebay for $149.00.
    • Official Post
    Here is an Ebay auction for a used HCC-AX steering gear box tag by Ebay member "mustangeer" with a Buy-It-Now of $255.00:
    Original factory stamped HCC AX, for identification of steer column 16:1 quick-ratio gear-box w/ MS manual steering use. Bright sheet steel tag dated 5L08B (1965 November 8th), simply fastens to a box cover mounting bolt. Fairly flat w/ some pitting, well-defined lettering, a noticeable detailing part that many cars have lost over the years. From a ’66 A-code / K-code, it suits ’65 models as well, however the 19:1 ratio MS / PS applications are each different. It’s an OEM Ford production item w/ correct form & fit, for a Shelby GT350 & GT350H / 2+2 fastback / Hi-po coupe / GT convertible, why go without one.
    1965 1966 Ford Mustang Steering Box Tag ID Manual Quick GT 289 Hipo OEM HCC-AX | eBay
    • Official Post
    This used HCC-AX steering gear box tag sold July 6, 2026 on Ebay for $255.00.
