Used C3OF-AJ Hipo Carburetor
  • Here is an Ebay auction for a used C3OF-AJ Hipo carburetor by Ebay member "stonemanofwaxhaw" with a Buy-It-Now of $4,200.00 or make offer:
    AUCTION IS FOR ONE (1)
    Autolite 4100 HiPo Carburetor C3OF-AJ
    Date Code A 4 AE = Jan 1964 5th week
    Original to: Ford AC Cobra Shelby Fairlane K Code
    Also Fits: Ford Mustang Shelby Fairlane Cougar Thunderbird
    Very nice original Autolite 4100 HiPo Carburetor C3OF-AJ offered for sale! This is a very rare and hard to find carburetor that was used on the early 289 K Code HiPo engines. This is the early Auto-choke version.
    The Carburetor was disassembled and inspected! It was carefully and gently cleaned, with the preservation of the original finishes and patina in mind. The inside was cleaned and rebuilt using new style needle and seats but keeping the original brass floats. All new gaskets, power valve and diaphragms were installed. The hard to find original float return springs and fuel transfer baffles were also reinstalled. The body and mechanical parts are all original and are in perfect shape!
    Note: The mechanical parts like the throttle shaft and choke shafts appeared to be in excellent condition and were not removed. Original clips and fasteners reused where possible!
    Great candidate for a high-level restoration or use as is and keep the patina!
    Please look over the photos, if you have any questions just ask!
    Shipping is included in the lower 48 states.
    Sold as is, No Returns!
    Buyer should verify if these fit your application before bidding.
    NO RESERVE AUCTION! HAPPY BIDDING!
    GOING THRU MY STUFF IN THE GARAGE & THE ATTIC. LOTS OF RARE & VERY COLLECTIBLE STUFF. MOST OF IT IS IN MINT CONDITION! PLEASE CHECK OUT MY AUCTIONS FOR MORE STUFF INCLUDING NOS & AFTERMARKET CAR PARTS.
    Autolite 4100 HiPo Carburetor C3OF-AJ Ford AC Cobra Shelby Fairlane K Code | eBay
  • The listing for this used C3OF-AJ Hipo carburetor was ended by the seller November 25, 2022 with the folllowing explanation "This listing was ended by the seller because the item is no longer available".
  • This used C3OF-AJ Hipo carburetor that was "no longer available" is back on Ebsay again with no changes to the Buy-It-Now of $4,200.00:
  • This used C3OF-AJ Hipo carburetor sold December 4, 2022 on Ebay for $3,800.00.
  • Here is an Ebay auction for a used C3OF-AJ Hipo carburetor by Ebay member "jefledyar0" with a starting bid of $2,000.00:
    Item: Vintage Autolite 4100 4-Barrel Carburetor (1.12 Venturi "HiPo" Core)Part Number: C3OF-AJOriginal Metal Tag Included: C3OF-AJ / A 4ABHistorical Vehicle Applications:1963–1965 Shelby Cobra 289 (CSX Series Leaf-Spring Cars)1965 Shelby Mustang GT3501963–1965 Ford Mustang "K-Code" 289 High Performance (HiPo)1963–1964 Ford Fairlane & Mercury Comet HiPoDescription:Up for sale is an incredibly rare, highly sought-after Autolite 4100 4-barrel carburetor, model C3OF-AJ with the 1.12 venturi size. This is a factory "HiPo" (High Performance) core designed specifically for Ford's legendary solid-lifter 289ci High-Performance V8 engine.What makes this unit exceptionally valuable to a high-end collector is that it retains its original factory aluminum identification tag stamped C3OF-AJ and date code A 4AB.Date Code Breakdown (4AB):4 = 1964A = NovemberB = 2nd WeekThis November 1964 build date makes it a historically accurate period-piece component for a concours restoration of a Late 1964 / early 1965 Shelby Cobra 289, an early 1965 Shelby GT350, or a 1965 Mustang K-Code.Condition, Known Defects, & Disclaimers:Please read carefully before bidding or buying. I am not a carburetor specialist or mechanic, so I am listing this with full transparency regarding its current condition:Excellent Internal Movement: For a vintage core, this unit is in great shape mechanically. All throttle blades, linkages, and external mechanisms move smoothly and freely. Nothing is seized or rusted solid.95% Complete & All-Original: To the best of my estimation, this carburetor is roughly 95% complete with its original factory components. Both internal float bowl vent tubes are present and intact.Broken Choke Thermostat Cap: The round, black plastic choke thermostat cap on the side of the housing is broken/damaged and will need to be replaced by the buyer during the rebuild.Sold AS-IS for Rebuild/Restoration: This unit is being sold strictly AS-IS for parts, rebuild, or a full professional restoration. It has not been tested on a running vehicle. It features a beautiful, uncleaned "barn find" vintage patina.Best of My Knowledge / Final Sale: All information listed here is provided strictly to the best of my knowledge and visual inspection. As a non-expert, I may have missed a minor internal clip, screw, washer, or specific component. Please study the high-resolution photos closely, as what you see in the pictures is exactly what you will receive. No warranties are expressed or implied, and all sales are final.These authentic HiPo C3OF-AJ carbs with their original factory date tags are incredibly difficult to find intact. This is the ultimate starting core for a high-end Shelby or K-Code build
    C3OF-AJ Autolite 4100 Carburetor 1.12 289 Mustang Shelby Comet HiPo Ford W/Tag | eBay
    This used C3OF-AJ Hipo carburetor received no bids by July 27, 2026 and therefore did NOT sell.
  • This used C3OF-AJ Hipo carburetor is back on Ebay again with the same starting bid of $2,000.00:
  • The listing for this used C3OF-AJ Hipo carburetor was ended by the seller July 28, 2026 with the folllowing explanation "This listing was ended by the seller because the item was lost or broken".
