C6OE 8505 A Rebuilt Hipo Water Pump
  • Here is an Ebay auction for a rebuilt C6OE 8505 A Hipo water pump by Ebay member "hartbrothers" with a Buy-It-Now of $624.99:
    Up for Sale:
    Restored Original Water Pump
    Applications:
    1966-67 Ford vehicles with Hi-po K code 289ci engines
    1966-67 Mercury vehicles with Hi-po K code 289ci engines
    Please refer to the compatibility section to verify your vehicle.
    Specifications:
    Casting Numbers: C6OE-A
    Date Code: N/A
    Core Refund: $200for an original C6OE core
    This is a original casting number C6OE-8505-A, C60E-8505-A and comes with the correct new aftermarket Hi-Po 6-fin curved fin cast iron impeller.
    Warranty: 90 Day
    New mounting gaskets and divider plate included with purchase.
    The quality of our rebuilds will speak for themselves, these water pumps have been through a meticulous process to make sure they meet or exceed industry standards.
    New bearings and seals were used to restore this to OE standards.
    If you have any questions regarding this item contact us by email.
    Restored 1966-67 Shelby Mustang Cougar 289ci Hi-Po "K" water pump C6OE-8505-A | eBay
  • This rebuilt C6OE 8505 A Hipo water pump sold April 21, 2022 for $511.99.
  • Here is another Ebay auction for a rebuilt C6OE 8505 A Hipo water pump by Ebay member "hartbrothers" with a Buy-It-Now of $624.99:
    Up for Sale:
    Applications:
    Specifications:
    Date Code: N/A
    Core Refund: up to $200 for an original C6OE core
    This is a original casting number C6OE-8505-A and comes with the correct new aftermarket Hi-Po 6-fin curved fin cast iron impeller.
    Warranty: 180 Day
  • This rebuilt C6OE 8505 A Hipo water pump sold February 4, 2023 for $529.40.
  • Here is an Ebay auction for a rebuilt C6OE 8505 A Hipo water pump by Ebay member "2ndgenautoparts" with a Buy-It-Now of $550.00:
    1966-67 Ford Vehicles 289ci 4.7L V8 engines.
    1966-67 Mercury Vehicles 289ci 4.7L V8 engines.
    ALL "K" code HI-PO performance engines.
    Please use the compatibility section to verify your specific application.
    The casting number is C6OE-8505A.
    This water pump casting number was introduced after the C5OE-8505 that was used from May of 1965 to August 1965.
    This water pump has the HI-PO Cast Iron curved 6-Fin impeller.
    NOTE: There is a $100.00 refundable core deposit included in the purchase price upon the return of your original Ford C6OE-8505A casting.
    This rebuilt Ford water pump comes with a 6 month warranty and a new mounting gasket.
    If you have any questions regarding this item contact me by email.
    1966-67 Ford Mercury Vehicles 289 4.7 HIPO "K" V8 Rebuilt water pump C6OE-8505A | eBay
  • The seller ended this listing April 16, 2024 with the following explanation "this item is no longer available".
  • This rebuilt C6OE 8505 A Hipo water pump that was "no longer available" is back on Ebay again with a new much higher Buy-It-Now of $675.00:
    1966-67 Ford Mercury Vehicles 289 4.7 HIPO "K" Rebuilt water pump C6OE-8505A-7 | eBay
  • Here is an Ebay auction for a rebuilt C6OE 8505 A Hipo water pump by Ebay member "2ndgenautoparts" with a Buy-It-Now of $750.00:
    Up for sale is a professionally rebuilt water pump for the following applications:
    The casting number is C6OE-8505A and 20.
    This water pump has an original HI-PO C3OE-8512-A Cast Iron curved 6-Fin impeller.
    1966-67 Ford Mustang Mercury 289 HIPO K CODE Rebuilt water pump C6OE-8505A | eBay
  • Here is an Ebay auction for a rebuilt C6OE 8505 A Hipo water pump by Ebay member "2ndgenautoparts" with a Buy-It-Now of $675.00:
    The casting number is C6OE-A and 35.
    This water pump has a HI-PO Cast Iron curved 6-Fin impeller.
    NOTE: There is a $100.00 refundable core deposit included in the purchase price upon the return of your original Ford C6OE-A casting.
    1966-67 Ford Mustang Mercury 289 HIPO K CODE Rebuilt water pump C6OE-A 35 | eBay
  • Here is an Ebay auction for a rebuilt C6OE 8505 A Hipo water pump by Ebay member "Marvelous Parts of Oregon" with a Buy-It-Now of $700.15 or make offer:
    Up for sale
    Professionally Rebuilt Original Water Pump
    Applications:
    Specifications:
    Core Refund: No core charge
    Contact us if you have a pump you wish to get rebuilt.
    This pump has a Reproduction "Hipo" Impeller.
    Smaller diameter and less fins for improved cooling at higher RPM's,
    Higher pressure in the coolant system to reduce hot spots,
    and the formation of steam pockets. Cooler running engine.
    Warranty: 6 Month
    1966-67 Ford Mustang Cougar Shelby 289ci Hipo K code Rebuilt Water Pump C6OE-A | eBay
  • This listing was ended by the seller February 14, 2025 with the following explanation "the item is no longer available".
    The casting number is C6OE-A and 27.
    1966-67 Ford Mustang Mercury 289 HIPO K CODE Rebuilt water pump C6OE-A 27 | eBay
  • This rebuilt C6OE 8505 A Hipo water pump received no bids by June 26, 2025 and therefore did NOT sell.
  • Here is an Ebay auction for another rebuilt C6OE 8505 A Hipo water pump by Ebay member "2ndgenautoparts" with a Buy-It-Now of $675.00:
    The casting number is C6OE-A and 29.
    1966-67 Ford Mustang Mercury 289 HIPO K CODE Rebuilt water pump C6OE-A 29 | eBay
  • This listing was ended by the seller December 9, 2025 with the following explanation "the item is no longer available".
  • This listing was ended by the seller February 17, 2026 with the following explanation "the item is no longer available".
  • Here is an Ebay auction for a rebuilt C6OE 8505 A Hipo water pump and timing cover by Ebay member "goldilocks3791-0" with a Buy-It-Now of $650.00:
    C60E-A water pump and C50OE-6059-A1 timing chain cover. Pump has been rebuilt, (both parts are displayed in raw metal, ready for paint). Please see all photos for condition. Both are used vintage parts
    HIPO 289 WATER PUMP, K Code, C60E-A Casting, Rebuilt, Orig TIMING CHAIN COVER | eBay
