Used Heater 65/66 Delete Setup
  • Here is an Ebay auction for a used 65/66 heater delete setup by Ebay member "pashli0" with a starting bid of $450.00:
    Heater delete kit (complete) consisting of original Ford used and NOS parts. See photos. Included are two NOS rubber heater block-off plugs (engine side) and two heater hose plugs (cowl panel) and two NOS nuts for mounting the J-brackets on the duct to cowl flange. All other parts are used originals. Some parts have been painted to prevent rust in storage. Passenger side duct marking is difficulty to see in the photos but is marked C0DB with the Fomoco logo. The duct is not perfect (9 out of 10), but is solid and functions properly with no repairs (correct for passenger side). Both used original hardware and correct NOS hardware will be included in the package as shown in the photos. An original firewall dash pad section to fill in where the blower motor is normally mounted is also included. I've also managed to locate two Wittek tower-style clamps for the engine-side block-off rubber plugs. They are both marked "1 1/16 " and date coded "2/64". They are used original parts and would need to be properly detailed. This would make a VERY nice, factory correct detail upgrade for an original Shelby Mustang.
    65 66 1965 1966 Mustang Shelby Heater Complete Used & NOS | eBay
    This used 65/66 heater delete setup sold March 26, 2022 on Ebay for $665.00 with 6 bids from 6 bidders.
    • Official Post
    Here is an Ebay auction for a used 65/66 heater delete setup by Ebay member "pashli0" with a starting bid of $795.00:
    Early Ford heater delete kit assembled for use with early Mustangs and Shelbys. This kit consists of original and NOS Ford parts as follows:
    1. Passenger-side air duct: C0DB , appears as NOS, but with minor damage on mounting lip (see photos). Has internal brackets for use with J-rod mounting brackets; correct passenger side door;
    2. Engine side rubber block-off caps, QTY 2, NOS, part C4TZ-8A500-A;
    3. Tower Clamps: QTY 2, NOS, Wittek, marked 1" and date coded 2/65;
    4. Firewall hose-delete plugs: QTY 2, NOS, part 377678-S;
    5. Delete Plate firewall: NOS (originally purchased with the passenger side air duct described above); appears as NOS never installed; has original holes for RPO installation as well;
    6. Mounting hardware duct, Original used J-rods and incorrect nuts (also to be included are two correct NOS mounting nuts 353911-S;
    7. Delete plate: interior dash panel. QTY 2, one appears as NOS original (no Ford markings on backside) and will include 2 correct PAL nuts part number 376642-S35 (it is missing the rear-side bracket), the other plate appears as an early repro? and has the Ford logo and part number C4ZA on the backside (includes original mounting hardware as shown in photos). Both plates appear to have never been installed.
    Missing Items from kit:
    1. Firewall sound deadener pad cutout section. This could be easily made from a "donor" original firewall pad if desired.
    2. interior dash heater control block-off plate mounting bracket.
    3. Sheet metal screws for delete plate to firewall mounting. These are readily available.
    You will receive all items as shown in the photos. Thank you
    65 66 1965 1966 Mustang Shelby Heater Optional Kit NOS | eBay
  • This used 65/66 heater delete setup sold April 14, 2021 on Ebay for $795.00.
  • Here is an Ebay auction for a used 65/66 heater motor delete plate by Ebay member "pashli0" with a starting bid of $25.00:
    Original USED Ford heater delete plate for firewall installation on early Mustangs and Falcons (possibly other models) with the heater delete option. This item has had two minor repairs made to it (cosmetic only) and has been repainted black. All mounting holes are original. Please see photos. Original hard to find part in very usable condition.
    65 66 1965 1966 Ford Mustang Falcon Shelby Firewall Block Off Plate USED | eBay
    This used 65/66 heater motor delete plate sold April 18, 2022 on Ebay for $46.00 with 4 bids from 3 bidders.
    • Official Post
    Here is an Ebay auction for a used 65/66 heater delete setup by Ebay member "lunch_pail_parts" with a Buy-It-Now of $1,750.00 or make offer:
    Another rare, obsolete Lunch Pail part !
    These parts are original equipment for any 1965-66 Mustang with the 'Heater Delete' option, including all early '65 ('1964½') models and any Shelby GT350 units, so equipped.
    The duct housing is fully intact and functional. The dash 'blank' still has its delicate locating tabs. You even get the original mounting hardware, so installation will be easy!
    It's all in truly mint condition... guaranteed good enough for even the finest show car. Why mess with fabricating 'close' fakes if you can have the real deal, looking this good?
    RARE 1965 1966 Ford Mustang heater delete Shelby GT350R Hawaii Florida 64½ A/C | eBay
    • Official Post
    The seller ended this listing June 12, 2022 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • Here is an Ebay auction for a used 65/66 dashboard heater delete plate by Ebay member "classiccarsandjeepparts" with a Buy-It-Now of $200.00:
    Original take off from a 1965 Shelby K Code Heater Delete Plate
    Has a crack at the bottom see pictures.
    Cool original part to have for your Shelby or Shelby Replica.
    1964-1966 Mustang (1965 factory Shelby) Original Heater Control Delete Plate | eBay
  • Here is an Ebay auction for a used 65/66 clone heater delete vent assembly by Ebay member "mustangmasters428" with a starting bid of $395.00:
    Here we have a rather rare item, a Fresh Air Vent useable for a Heater box delete assembly for a 64-66 Shelby Clone Mustang or Falcon. This original Air Duct with door is paired with a aftermarket heater control dash blank-out plate. This item was used to reduce the weight of these early high-performance cars by replacing the heavy heater blower and related items with this light, fiberglass and metal assembly. The plastic dash blank-out plate was made to replace the cable control to finish out the look allowing you to remove the now-useless heater controls from your dash.
    All pieces are in good condition, with a few easily repaired blemishes. The fiberglass on the box is intact and the door is easily opened. The plastic dash blank-out plate and the finish on both are in good condition with no damage. Ready to install with no work needed this is ready to go kit for that driver Shelby GT 350 Mustang or Falcon stock car owner.
    Another bit of Mustang Racing Nostalgia that would be great for your parts closet ("Yeah, but do you have one of THESE?") or to be added to that original Mustang, Shelby, or Falcon! Whether you have a cloned GT350, or Hertz, or HiPo 289 Fastback, this replacement piece was standard equipment for these early factory race cars.
    1965-66 Shelby Heater Box Delete Falcon Fresh Air Vent Mustang Heater Box Clone | eBay
    • Official Post
    This used 65/66 clone heater delete vent assembly received no bids by April 30, 2023 and therefore did NOT sell.
  • This used 65/66 clone heater delete vent assembly is back on Ebay again with the same starting bid of $395.00:
  • This used 65/66 clone heater delete vent assembly received no bids by September17, 2023 and therefore did NOT sell.
    • Official Post
  • Here is an Ebay auction for a NOS 65/66 heater delete vent assembly by Ebay member "mustangsetc" with a starting bid of $375.00:
    Here is a very rare NOS Heater Delete Vent Assembly that will fit 1965-1966 Mustangs and Shelby GT350's. This is the only component of the highly sought after "Heater Delete" option that is not reproduced.
    This particular item has never been installed but it does have some mold flaws and shows some shelf wear. Being a service item, this vent is molded from a black plastic rather than horsehair fiberglass, but it will be very hard to tell once installed. The vent door opens and closes easily. There is one small chip on the mounting surface lip which will not be visible once installed. I don't have original mounting hardware to go with it (they were serviced under another part number and not included with the vent assembly) but I will include some J-hooks that are the same length as original, just a slightly larger diameter rod and fully functional.
    If you have any questions please contact us before bidding. Good luck!
    NOS Heater Delete Vent Assembly Mustang Falcon Shelby GT350 1965 1966 65 66 | eBay
  • Phill, It is the real deal, just a later Ford replacement part. What he has here is the last version which is now obsolete and the worldwide stock has dried up. There will not be any more of these produced and certainly not in stock anywhere.
    On a similar Ford part that went through a Ford manufacturing transition, the original C5ZZ 18471 A defroster plenums were cardboard and the first Ford replacements were a nasty rough fiberglass piece that had no engineering numbers on them. I had some of those at one time and the next version was the hard plastic type with Ford engineering numbers on them. I still have some of those later NOS plastic versions in stock. They are more similar to the current aftermarket ones but with Ford engineering numbers.
    I actually do have one of these same NOS right side air vent in stock. Keep in mind that Ford produced early Falcons in Argentina through 1991, long after the cars were no longer produced in the U.S. The early Falcon was very popular there.
  • This used 65/66 clone heater delete vent assembly received no bids by March10, 2024 and therefore did NOT sell.
  • This NOS 65/66 heater delete vent assembly sold March 18, 2024 on Ebay for $478.00 with 5 bids from 2 bidders.
    • New
    • Official Post
