• Here is an Ebay auction for a used set of Hipo main bearing caps by Ebay member "phcap53" with a Buy-It-Now of $1,400.00 or make offer:
    Original Ford 289 Hipo block main caps off a K code Mustang.Used these on Shelbys also so look at pics and actual total will follow with buyer provided info after auction
    Ford 289 Hipo Block Main Caps | eBay
    The listing for this set of used Hipo main bearing caps was ended by the seller August 22, 2026 with the following explanation "the item is no longer available".
  • Here is an Ebay auction for a used pair of #2 and rear Hipo main bearing caps by Ebay member "mabu8414" with a Buy-It-Now of $325.00 or make offer:
    Pair of two Ford 289 HiPo main bearing caps. This is NOT a complete set. Included are the #2 main cap and the end main cap with the oil pan seal area.
    These are used parts and are being sold exactly as shown in the photos. Please review all pictures carefully before purchasing.
    ● Includes only 2 main caps: #2 and end cap
    ● Casting marks are visible on the caps
    ● One cap still has a bearing installed
    ● Surface rust is present in areas
    ● Some areas show light rust staining/roughness; condition should be judged from the photos
    ● Used condition with normal signs of age and prior use
    ● No claim is made that these have been professionally inspected, measured, or tested
    ● Not a complete set of 289 HiPo main caps
    Please verify casting numbers, markings, dimensions, and application before purchasing to ensure these are correct for your project.
    Sold as pictured. What you see in the photos is what is included.
    Ford 289 HiPo Main Caps #2 & End Cap High Performance 289 V8 Used Parts | eBay
  • This used pair of #2 and rear Hipo main bearing caps sold August 17, 2026 on Ebay for $325.00.
