Here is an Ebay auction for a used Tri Power intake and carburetor setup by Ebay member "stran.fra " with a starting bid of $2,899.00:
tri power 3x2 ford shelby cobra hipo k code intake carbs linkage fuel log. Condition is "Used". Please note the date code clearly visible on the water neck, this is a FACTORY installed small block trippier, as the parts counter intakes did not normally have a date code! If your cobra was a factory tri power this is it! This is a complete assembly with air cleaner, however the air cleaner housing is off a big block, and the fins go all they way to the end. Thinning my collection if you want it buy now or you’ll regret it, this will set any small block away from the rest. |
tri power 3x2 ford shelby cobra hipo k code intake carbs linkage fuel log | eBay
