Used 66 Radio Block Off Plate
  • Here is an Ebay auction for a used 66 radio block off plate by Ebay member "gtmotorsports66 " with a starting bid of $95.00:
    Here up for auction is a very nice in used condition 1966 Mustang, Shelby, 66 Trans Am radio delete block off plate in black. The Ford engineering casting number is C6ZB-6504371-AW and with the Fomoco logo. It has two 1/4 in. screw studs approx.1 in. long installed on each side possibly because the original plastic metal nut's screw threads on were stripped off at one time some how but this being replaced still works perfectly as it was designed to. The shipping is for only in the lower 48 USA State's. Good Luck & Happy Bidding !!
    https://www.ebay.com/itm/1966-…74af76:g:~dIAAOSwgTpehliS
  • This used 66 radio block off plate received no bids by April 12, 2020 and therefore did NOT sell.
  • This used 66 radio block off plate is back on Ebay again with a starting bid of $105.00:
    https://www.ebay.com/itm/17424…vxp=mtr&item=174249044620
  • This used 66 radio block off plate received no bids by April 22, 2020 and therefore did NOT sell.
  • This used 66 radio block off plate is back on Ebay again with no changes:
    https://www.ebay.com/itm/17425…vxp=mtr&item=174259136844
  • This used 66 radio block off plate received no bids by May 2, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/17426…vxp=mtr&item=174269695225
  • Here is an Ebay auction for a used 66 radio block off plate by Ebay member "69gt-500" with a Buy-It-Now of $179.95 or make offer:
    1966 Ford Shelby GT-350 Mustang Fastback 2+2 GT Coupe Convertible Radio Delete Block Off Plate
    This is the read deal, Genuine Ford, not a repop or a fake one
    This was stored away for many years and it’s time to pass it on.
    Please look at the pictures and ask any questions BEFORE you bid!! I want you to be sure of what you are bidding on and for us both to be satisfied with the item and its sale. These are over 50 year old mass produced parts !
    Has FOMOCO LOGO and FORD PART#'s CAST IN C6ZB-6504371-AW along with the crazy mix of leftover plastic colors to produce that unique design.
    Perfect for that killer Thoroughbred Concours restoration.
    https://www.ebay.com/itm/66-19…nc&_trksid=p2047675.l2557
    Why settle for some CHEAP Reproduction
    Please look at all of the pictures and ask any questions prior to bidding
    Thanks and good luck
    Remember:" Reproduction parts have no collector Value"
    Genuine Ford Parts Are: "Made Right", "Fit Right", "Last Longer" and make your car more valuable!
  • The listing for this used 66 radio block off plate was ended by the seller April 11, 2020 with the following explanation "his listing was ended by the seller because the item is no longer available".
  • The listing for this used 66 radio block off plate that was "no longer available" is back on Ebay again with a new higher Buy-It-Now of $199.95 or make offer:
    https://www.ebay.com/itm/66-19…8bf201:g:Ki4AAOSwEy1eL5Ka
  • This used 66 radio block off plate received no bids by May 12, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/17428…vxp=mtr&item=174281229841
  • This used 66 radio block off plate received no bids by May 22, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/1966-…nc&_trksid=p2047675.l2557
  • The listing for this used 66 radio block off plate was ended by the seller May 22, 2020 with the following explanation "This listing was ended by the seller because there was an error in the listing".
    https://www.ebay.com/itm/1966-…id=p2047675.c100036.m2109
  • This used 66 radio block off plate received no bids by June 1, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/17430…vxp=mtr&item=174303626654
