Used C5DA Bellhousing
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "bigjon427" with a starting bid of $249.99:
    Ford C5DA-6394-A This auction is for a good used Original Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford Mustang Shelby GT350 Cougar Fairlane Torino Cyclone Comet Montego and Ranchero. This fits 289 289 HiPo Special 302 V8's with 3 and 4 speed manual transmissions. In as found condition, the outside has some black paint on it. The inside is bare aluminum which has some oxidation on it. I have not tried to clean it up. It also has a couple of chips, dents or gouges on the edge. looks like someone may have used a screwdriver to pry it loose from the engine. Otherwise it is not damaged. Please do your own research for fitment to see if this item will suit your needs.
    1965 1966 1967 1968 FORD 65 MUSTANG 289 302 3 4 SPEED BELL HOUSING C5DA-6394-A | eBay
    This used C5DA bellhousing received no bids by February 20, 2022 and therefore did NOT sell.
    This used C5DA bellhousing is back on Ebay again with a new lower starting bid of 199.99:
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "auntiek351" with a Buy-It-Now of $379.99:
    This auction is for a clean used Original Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford Mustang Shelby GT350 Cougar Fairlane Torino Cyclone Comet Montego and Ranchero. This fits 289 289 HiPo Special 302 V8's with 3 and 4 speed manual transmissions. It includes the clutch fork pivot and accepts a 157 tooth flywheel. It is clean and ready to install. It will also work on 1969 and newer 302 and 351 if you change the clutch fork pivot or use the early clutch fork. If you need the 1969 and newer pivot I will swap it out for you no charge. It carries Ford ID number C5DA-6394-A . We accept Paypal , Visa, Mastercard, Discover and American Express. If you have any questions or need other clutch linkage or 4 speed components, please ask. Thank-you and Happy Ebaying! (021522)
    1965 1966 1967 1968 FORD MUSTANG 289 302 3 4 SPEED BELL HOUSING C5DA 157 Tooth | eBay
    This used C5DA bellhousing sold February 23, 2022 on Ebay for $379.99.
    • Official Post
    This used C5DA bellhousing sold February 27, 2022 on Ebay for $212.50 with 3 bids from 2 bidders.
  • Here is another Ebay auction for a used C5DA bellhousing by Ebay member "auntiek351" with a Buy-It-Now of $349.99:
    This auction is for a clean used Original Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford Mustang Shelby GT350 Cougar Fairlane Torino Cyclone Comet Montego and Ranchero. This fits 289 289 HiPo Special 302 V8's with 3 and 4 speed manual transmissions. It includes the clutch fork pivot and accepts a 157 tooth flywheel. It has a small chip by one of the dowel pin holes ( see pictures) which will not affect the performance of the bell housing. All the threads are good and have been chased with a tap. It is clean and ready to install. It will also work on 1969 and newer 302 and 351 if you change the clutch fork pivot or use the early clutch fork. If you need the 1969 and newer pivot I will swap it out for you no charge. It carries Ford ID number C5DA-6394-A and has a 65 Date. We accept Paypal , Visa, Mastercard, Discover and American Express. If you have any questions or need other clutch linkage or 4 speed components, please ask. Thank-you and Happy Ebaying! (031222)
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "metlcwest" with a Buy-It-Now of $280.00 or make offer:
    65-67 289 hipo Mustang 70 302 Maverick. 65-66 289 falcon. 65-68 mustang 289 Bell Housing C5DA-6394-A 6 volt pattern . uses 157 tooth flywheel . WITH FORK Has been vatted bead blasted and primered all thread chased. No C5DA-6394-A stamped on bell housing. Any questions please email and ask. Check out our store. Thanks for ebaying with us.
    65-67 289 hipo Mustang 70 302 Maverick Bell Housing C5DA-6394-A & FORK | eBay
    This used C5DA bellhousing sold March 18, 2022 on Ebay for $280.00.
  • Here is another Ebay auction for a used C5DA bellhousing by Ebay member "metlcwest" with a Buy-It-Now of $280.00 or make offer:
    65-67 289 hipo Mustang 70 302 Maverick. 65-66 289 falcon. 65-68 mustang 289 Bell Housing C5DA-6394-A 6 volt pattern . uses 157 tooth flywheel . Has been vatted bead blasted and primered all threads chased. # C5DA-6394-A stamped on bell housing. Any questions please email and ask. Check out our store. Thanks for ebaying with us.
    65-67 289 hipo Mustang 70 302 Maverick Bell Housing C5DA-6394-A | eBay
    This used C5DA bellhousing sold March 22, 2022 on Ebay for $349.99.
  • Here is another Ebay auction for a used C5DA bellhousing by Ebay member "auntiek351" with a Buy-It-Now of $379.99:
    This auction is for an extremely clean used Original Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford Mustang Shelby GT350 Cougar Fairlane Torino Cyclone Comet Montego and Ranchero. This fits 289 289 HiPo Special 302 V8's with 3 and 4 speed manual transmissions. It includes a NOS clutch fork pivot and accepts a 157 tooth flywheel. It is clean and ready to install. It will also work on 1969 and newer 302 and 351 if you change the clutch fork pivot or use the early clutch fork. If you need the 1969 and newer pivot I will swap it out for you no charge. It carries Ford ID number C5DA-6394-A . We accept Paypal , Visa, Mastercard, Discover and American Express. If you have any questions or need other clutch linkage or 4 speed components please ask. Thank-you and Happy Ebaying! (032422)
    This used C5DA bellhousing sold March 27, 2022 on Ebay for $280.00.
    • Official Post
    This used C5DA bellhousing sold April 1, 2022 on Ebay for $379.99.
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "jbford1sports" with a Buy-It-Now of $375.00:
    For sale pictured Bellhousing for 65 thru 68 Mustangs and 67 and 68 Cougars. Ford casting # C5DA-6394-A. It is for a 157 tooth flywheel. The bellhousing has no cracks or breaks and is in good used condition. Free shipping in the continental USA. Thanks for looking!
    1965 1966 1967 1968 Ford Mustang 289 302 3 4 Speed Bellhousing Fastback | eBay
    • Official Post
    This auction is for an extremely clean used Original Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford Mustang Shelby GT350 Cougar Fairlane Torino Cyclone Comet Montego and Ranchero. This fits 289 289 HiPo Special 302 V8's with 3 and 4 speed manual transmissions. It includes the clutch fork pivot and accepts a 157 tooth flywheel. It is clean and ready to install. It will also work on 1969 and newer 302 and 351 if you change the clutch fork pivot or use the 1965 clutch fork. If you need the 1969 and newer pivot I will swap it out for you no charge. It carries Ford ID number C5DA-6394-A and has a date code of 65. We accept Paypal , Visa, Mastercard, Discover and American Express. If you have any questions or need other clutch linkage or 4 speed components please ask. Thank-you and Happy Ebaying! (040522)
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing w/spacer plate by Ebay member "pashli0" with a starting bid of $395.00:
    Used later style (6 bolt) aluminum bell housing/scattershield correct for early Mustang and other Ford SBF applications with manual toploader 4-speed setups. May have other applications. Part is stamped C5DA. Item also includes used original Ford steel spacer plate as shown in the photos. Both items are in good/excellent condition. (the engine spacer plate has very minor pitting as shown in the photos, but is otherwise free of any bends, repairs, defects or modifications). Threads in housing are all in excellent condition. no cracks, repairs, etc. clutch pivot bracket is firmly mounted. Overall an excellent item with a hard-to-find and correct 6 bolt spacer plate. please see photos.
    65 66 1965 1966 Ford Mustang Shelby 6 Bolt Scattershield C5DA w/spacer plate | eBay
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "munson6566" with a Buy-It-Now of $499.95:
    YOU ARE VIEWING AN ORIGINAL FORD C5DA 157 TOOTH ALUMINUM BELLHOUSING .
    THE PART NUMBER IS : C5DZ 6392 A
    THE ID NUMBER IS : C5DA 6394 A JUNE 1965 DATED
    THIS IS A NICE ORIGINAL FORD ALUMINUM BELLHOUSING USED ON A SMALL BLOCK WITH A 157 TOOTH FLYWHEEL .
    THIS BELLHOUSING HAS BEEN CLEANED, THREADS CHASED AND HAS NO CRACKS, REPAIRS OR HELI COILS .
    THIS BELL WILL WORK ON ANY 6 BOLT SMALL BLOCK WITH A 157 TOOTH FLYWHEEL .
    THE AUCTION IS FOR THE BELLHOUSING ONLY .
    THE BELLHOUSING HAS A EARLY WIRE STYLE PIVOT , IF YOUR RUNNING A 1968 AND LATER, SPRING STYLE FORK, YOU WILL NEED TO CHANGE THE PIVOT.
    THE BELLHOUSING HAS SOME CASTING FLASH ON IT ( PICTURE #6 ) , THERE IS NO DENT ON THE INSIDE, NO EXPLOSION.
    B429 BATT SHELF
    THIS FITS :
    1965 1966 1967 FORD MUSTANG FALCON SHELBY GT350 289 289 H/P ( 157 TOOTH FLYWHEEL ONLY )
    SHIPPING IS FOR THE CONTINENTAL UNITED STATES ONLY ( 48 STATES ). ALASKA,HAWAII,CANADA AND ALL OTHER LOCATIONS SHOULD CONTACT ME FOR A SHIPPING QUOTE.
    I INSURE ALL PACKAGES FOR FULL VALUE,NO EXCEPTIONS.
    IF YOU HAVE ANY QUESTIONS OR NEED MORE DETAILED PICTURES YOU CAN CONTACT THROUGH EBAY .
    ORIGINAL 1965 1966 1967 FORD MUSTANG 289 289 H/P ALUMINUM BELLHOUSING C5DA | eBay
  • Here is an Ebay auction for a used C5DA bellhousing w/spacer plate by Ebay member "pashli0" with a starting bid of $395.00:
    This used C5DA bellhousing w/spacer plate received no bids by April 13, 2021 and therefore did NOT sell.
  • This used C5DA bellhousing w/spacer plate is back on Ebay again with no changes:
    65 66 1965 1966 Ford Mustang Shelby 6 Bolt Bell Housing C5DA w/spacer plate | eBay
  • This used C5DA bellhousing w/spacer plate received no bids by April 20, 2021 and therefore did NOT sell.
