• Here is an Ebay auction for a used C5DA bellhousing by Ebay member "isayra" with a Buy-It-Now of $249.00 or make offer:
    Ford OEM C5DA-6394-A Bell housing. From early mustang GT and toploader manual transmission with small 157 tooth flywheel. A
    Light weight original unit, good threads. This housing is cracked in the clutch fork window area-see photos. This will not work with larger 164 tooth flywheel combinations. Email any questions. Shipping is whatever they charge me. thanks for looking
    REDUCED! 66 Mustang OEM Aluminum Bell housing C5DA-6394-A | eBay
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "mustangmanbob" with a Buy-It-Now of $245.00 or make offer:
    Original Ford cast aluminum manual transmission bellhousing casting number C5DA-6394-B
    157 tooth
    1965 1966 1967 1968 1969 1970 1971 1972 1973
    289 302 351W
    Please note most cars used a 164 tooth after 1968 but this will fit with the 157 tooth fly.
    Mustang Falcon Fairlane Ranchero Galaxie Torino Maverick Comet Montego
    This will work with many many Ford V8 engines including 289 302 and 351. Bellhousing has the correct factory drilled and tapped 6 bolt (1965 and up) mounting bolt pattern.
    Works with lots of different manual transmissions including 3 and 4 (top loader and Borg Warner) and 5 speed with the adapter plate.
    There are no cracks or repairs. All threads checked and are good. Please zoom in on all pictures. Pictures give the best description and information on the item.
    Clutch Ford included, and is FREE, as it is dirty.
    Fitment chart from factory
    C5DA usage also.
    C5DA-6394-A
    [Blocked Image: https://www.mustangtek.com/4100/images/289Hipo_000.jpg]
    65-66 289 Falcon 2v 3_4sp
    65-68 289 Mustang 2v 3_4sp
    65-67 289 Hipo Mustang 4sp from_8/20/64)
    65-67 289 Mustang Falcon 4v-PF 4sp
    70+ 302 Maverick w/MT
    Ford V8 Bell housing 4 5 Speed Trans 289 351W 302 C5DA-6394-A Mustang Fairlane + | eBay
  • This used C5DA bellhousing sold October 13, 2025 on Ebay for $245.00.
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "mustangmanbob" with a Buy-It-Now of $295.00 or make offer:
    157 tooth
    289 302 351W
    There are bolts threaded into the threaded holes.
    Clutch Fork included, and is FREE, as it is dirty.
  • This used C5DA bellhousing sold November 2, 2025 on Ebay for $295.00.
  • Here is an Ebay auction for a used C5DA bellhousing and clutch fork by Ebay member "mustangmanbob" with a Buy-It-Now of $285.00 or make offer:
    157 tooth
    289 302 351W
    There are bolts threaded into the threaded holes. I would run a tap in all of them just to make sure everything is good.
    Pictures give the best description and information on the item. Bolts are free, not correct length, just to test hole threads.
    C5DA usage also.
    C5DA-6394-A
    Shipping price is US 48 only, and ebay global shipping center.
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "renohamel66oo" with a Buy-It-Now of $250.00 or make offer:
    Here we have for sale a clean used Original 3 & 4 Speed Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford or Mercury with a 6 BOLT 289 302 289 HiPo V8. This has a Ford ID number C5DA-6394-A. It accepts a 157 tooth flywheel and both a 10" and 10 1/2" clutch and pressure plate. This is clean and ready to install. There is no damage or cracks in the aluminum. This will also fit a 1969 1970 1971 1972 1973 302 in a Mustang Fairlane Torino Ranchero Shelby GT350 Cougar Cyclone Comet Montego. Please ask any and all questions that you may have. Shipping will be through FedEx or UPS ground. Thanks for looking!
    1965-68 Ford Mustang Falcon V8 Aluminum 4 Speed Bell Housing 289 302 C5DA-6394-A | eBay
    This used C5DA bellhousing sold December 20, 2025 on Ebay for $250.00.
  • This used C5DA bellhousing sold December 26, 2025 on Ebay for $285.00.
    157 tooth
    289 302 351W
    This will work with many many Ford V8 engines including 289 302 and 351. Bellhousing has the correct factory drilled and tapped 6 bolt (1965 and up) mounting bolt pattern. It also has 2 extra holes drilled for the T5 adapter. They will not affect using a top loader, but I am pointing them out.
    There are no cracks or repairs, but there are 2 flaws
    1 tiny chipped being pointed to in picture 4. I would just put some epoxy on it
    Small chip in picture 6 on trans mouting hole. The bolt in it seats well and is very tight, so no impact.
    I have the T5 plate in another listing, and also a new engine trans spacer plate in another listing. If you want either or both of those, we can make a deal and no increase in shipping cost.
    There are bolts threaded into the threaded holes. I would run a tap in all of them just to make sure everything is good. Stud in starter hole to make it easier to hang the starter. It can be removed if desired.
  • Here is an Ebay auction for a used C5DA bellhousing and clutch fork by Ebay member "mustangmasters428" with a starting bid of $295.00:
    Here we have a factory original 6 bolt Bellhousing for a 3 or 4 speed Ford Transmission. Whether using this bellhousing for a Toploader or a T10, this small block bellhousing is just what's needed to bolt to that Ford 289, 302, or 351 with the 6 bolt pattern on the back of the block.
    This bellhousing has been cleaned, detailed, and inspected, and has been found to be free of damage and repairs. Commonly used in vehicles such as Mustang, Falcons, Fairlanes, Comets, Galaxies, and Rancheros, these are getting very hard to find, especially in a good clean undamaged condition. Unlike its automatic counterpart, which we have listed on eBay recently, we felt the call from our faithful customers to offer the standard shift version this week as part of our weekly offering of standard shift items such as transmissions, shifters, bellhousings, and flywheels.
    65-68 Mustang 351 302 289 HiPo 4 Speed 6 Bolt Aluminum Bellhousing C5DA-6394-A | eBay
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "FORD PARTS AND ACCESSORYS" with a Buy-It-Now of $393.33:
    This auction is for a very clean used Original 3 & 4 Speed Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford or Mercury with a 6 BOLT 289 302 289 HiPo V8. This is Ford part number C5DZ-6392-A with Ford ID number C5DA-6394-A and is DATED 65. It accepts a 157 tooth flywheel and both a 10" and 10 1/2" clutch and pressure plate. This has good threads and no cracks or breaks and is clean and ready to install. This will also fit a 1969 1970 1971 1972 1973 302 in a Mustang Fairlane Torino Ranchero Shelby GT350 Cougar Cyclone Comet Montego. This includes the original style clutch fork pivot. You are welcome to come to our central New Jersey shop to inspect or pick up. If you have any questions or need other clutch linkage components, please ask. Thank-you and Happy Ebaying! (012226)
    1965 66 67 1968 FORD 289 MUSTANG 3 & 4 SPEED BELL HOUSING FOR 157 TOOTH FLYWHEEL | eBay
    This used C5DA bellhousing sold January 22, 2026 on Ebay for $275.00.
    This used C5DA bellhousing sold February 11, 2026 on Ebay for $249.00.
    • Official Post
    157 tooth
    289 302 351W
    This will work with many many Ford V8 engines including 289 302 and 351. Bellhousing has the correct factory drilled and tapped 6 bolt (1965 and up) mounting bolt pattern. There is one alignment pin hole that has a chip, but this will not affect the transmission when installed.
    C5DA usage also.
    C5DA-6394-A
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "JOHN427" with a Buy-It-Now of $375.00 or make offer:
    Date code 1966 March
    Found this in a crate of my endless collection of vintage Mustang parts.it’s perfect for a real hipo car. Just cleaned it with Simple Green. Still has that stuff they use to use for corrosion protection on the sides was not going to hot tank it. The bolts and clutch fork come with it. Look at all the photos.
    FEEL FREE TO ASK ANY QUESTIONS??
    The product is a vintage 1965-1968 Ford 289 HIPO Mustang Shelby 4-speed bell housing, made in the United States. This performance part is a genuine Ford OEM part with the OE/OEM part number C5DZ6392A and manufacturer part number C5DA6394A. It is designed for a manual transmission and rear-wheel drive vehicles, specifically the Ford Shelby models.
    I even built a crate for it.
    WILL SHIP TO THE LOWER 49 STATES ONLY!!!
    1965 1966 1967 1968 FORD 289 HIPO MUSTANG SHELBY 4 SPEED BELL HOUSING EXCELLENT | eBay
    This used C5DA bellhousing sold March 7, 2026 on Ebay for $393.33.
    • Official Post
    Here is an Ebay auction for a used C5DA bellhousing by Ebay member "FORD PARTS AND ACCESSORYS" with a Buy-It-Now of $349.33:
    This auction is for a clean used Original 3 & 4 Speed Manual Transmission Bell Housing for a 1965 1966 1967 1968 Ford or Mercury with a 6 BOLT 289 302 289 HiPo V8. This is Ford part number C5DZ-6392-A with Ford ID number C5DA-6394-A. It accepts a 157 tooth flywheel and both a 10" and 10 1/2" clutch and pressure plate. This has good threads and is clean and ready to install. This will also fit a 1969 1970 1971 1972 1973 302 in a Mustang Fairlane Torino Ranchero Shelby GT350 Cougar Cyclone Comet Montego. This includes the later 1968 style clutch fork pivot. You are welcome to come to our central New Jersey shop to inspect or pick up. If you have any questions or need other clutch linkage components, please ask. Thank-you and Happy Ebaying! (033026)
    • Official Post
    This used C5DA bellhousing sold April 1, 2026 on Ebay for $285.00.
    • Official Post
    157 tooth
    289 302 351W
