• Here is an Ebay auction for a used C5DA bellhousing with fork by Ebay member "72rcode" with a Buy-It-Now of $295.00 or make offer:
    Ford 260 289 302 351C and 351W 6-bolt small block aluminum bell housing with an engineering number of C5DA-6394-A. Accepts a 157 tooth flywheel. Bell has been pressure washed and media blasted as seen in the pics, no cracks, breaks or repairs. All threads look good - missing the clutch fork pivot as shown. Dowel pin holes are intact. Also comes with a C80A-7515-A clutch fork that has been cleaned up as shown. Fork retaining spring is intact but throwout bearing ears have some wear as seen in the pics.
    Ford 289 302 351C 351W Manual Bell Housing C5DA-6394-A 6 Bolt 157 Tooth Mustang | eBay
    This used C5DA bellhousing sold December 29, 2023 on Ebay for $295.00.
  • Here is another Ebay auction for a used C5DA bellhousing by Ebay member "Total Productions" with a Buy-It-Now of 279.99 or make offer:
    THESE VINTAGE OEM/FACTORY PARTS ARE GETTING HARDER AND HARDER TO FIND, KEEP IT ORIGINAL AND GIVE AN OLD CAR PART A NEW HOME WITH THIS 65-70 FORD MUSTANG SHELBY FALCON 289 V-8 4 SPEED BELLHOUSING 6 BOLT C5DA-6394-A OEM 157 TOOTH
    65-70 FORD MUSTANG SHELBY FALCON 289 4 SPEED BELLHOUSING 6 BOLT C5DA-6394-A OEM | eBay
  • Here is an Ebay auction for a used C5DA bellhousing with fork by Ebay member "mustangmanbob" with a Buy-It-Now of $245.00 or make offer:
    Good original Ford Bell Housing that fits 289 302 and 351W engines.
    I have threaded bolts into the 4 trans mount holes and the 2 starter holes and the 2 spacer plate holes, and all is good.
    One small chip on an alignment hole that has no impact once installed. It is fully useable.
    The engine spacer plate shown in the last picture is NOT part of the listing, just shown for reference. If you need it, it is an extra $35, no shipping cost, if shipped with the bell housing. If you want it, please let me know and I will adjust the listing.
    Shipping price is US48 and ebay international only.
    C5DA-6394-A
    [Blocked Image: https://www.mustangtek.com/4100/images/289Hipo_000.jpg]
    1965-66 289 Falcon 2v 3_4sp
    65-68 289 Mustang 2v 3_4sp
    65-67 289 Hipo Mustang 4sp from_8/20/64)
    65-67 289 Mustang Falcon 4v-PF 4sp
    70+ 302 Maverick w/MT
    Ford Bell Housing C5DA 6394 A 1965 1966 67 68 3 4 Spd Mustang Falcon Fairlane + | eBay
    This used C5DA bellhousing sold February 2, 2024 on Ebay for $279.99.
  • This used C5DA bellhousing sold February 4, 2024 on Ebay for $245.00.
  • Here is an Ebay auction for another used C5DA bellhousing and block plate by Ebay member "auntiek351 " with a Buy-It-Now of $399.99:
    This auction is for a clean used Original 3 & 4 Speed Manual Transmission Bell Housing with Bell Housing to Engine Block Plate for a 1965 1966 1967 1968 Ford or Mercury with a 6 BOLT 289 302 V8. This is Ford part number C5DZ-6392-A and has Ford ID number C5DA-6394-A. It accepts a 157 tooth flywheel and both a 10" and 10 1/2" clutch and pressure plate. This has not been altered damaged or repaired and is clean and ready to install. This will also fit a 1969 1970 1971 1972 1973 302 in a Mustang Fairlane Torino Ranchero Shelby Cougar Cyclone Comet Montego. This has the 1968 and newer type clutch fork pivot and if you need I can supply the early style pivot at no additional cost. The bell housing plate to engine block plate is in excellent condition. We accept Paypal , Visa, Mastercard, Discover and American Express. If you have any questions or need other clutch linkage components, please ask. Thank-you and Happy Ebaying! (121023)
    1965 - 1968 FORD 289 3 & 4 SPEED BELL HOUSING w/ BLOCK PLATE FOR 157 TOOTH FLY | eBay
    This used C5DA bellhousing and block plate sold February 4, 2024 on Ebay for $375.99.
  • Here is an Ebay auction for another used C5DA bellhousing and block plate by Ebay member "FORD PARTS AND ACCESSORYS" with a Buy-It-Now of $399.99:
    This auction is for a clean used Original 3 & 4 Speed Manual Transmission Bell Housing with Bell Housing to Engine Block Plate for a 1965 1966 1967 1968 Ford or Mercury with a 6 BOLT 289 302 V8. This is Ford part number C5DZ-6392-A and has Ford ID number C5DA-6394-A. It accepts a 157 tooth flywheel and both a 10" and 10 1/2" clutch and pressure plate. This has not been altered damaged or repaired and is clean and ready to install. This will also fit a 1969 1970 1971 1972 1973 302 in a Mustang Fairlane Torino Ranchero Shelby Cougar Cyclone Comet Montego. This has the correct 1965 -1968 clutch fork pivot and if you need the later 1969 - 1973 style pivot I can include it at no additional cost. The bell housing plate to engine block plate is in very nice condition. We accept Paypal , Visa, Mastercard, Discover and American Express. If you have any questions or need other clutch linkage components, please ask. Thank-you and Happy Ebaying! (020525)
    PLEASE READ THE FOLLOWING CAREFULLY
    CONDITION
    ** PLEASE SEE ALL PICTURES AS THEY ARE A MAIN PART OF THE DESCRIPTION. NEED ANOTHER PICTURE PLEASE ASK.
    ** IN BEAUTIFUL PRE-OWNED GREAT QUALITY CONDITION
    ** STRAIGHT SOLID & COMPLETE
    ** GREAT CONDITION & FINISH OVERALL WITH NO ISSUES HERE DOES NEED CLEANING YET FULLY WORKING AND READY TO INSTALL
    C5DA-6394-A
    [Blocked Image: https://www.mustangtek.com/images/caution.jpg]65-66 289 Falcon 2v 3_4sp
    [Blocked Image: https://www.mustangtek.com/images/caution.jpg]65-68 289 Mustang 2v 3_4sp
    [Blocked Image: https://www.mustangtek.com/images/caution.jpg]65-67 289 Hipo Mustang 4sp from_8/20/64)
    [Blocked Image: https://www.mustangtek.com/images/caution.jpg]65-67 289 Mustang Falcon 4v-PF 4sp
    [Blocked Image: https://www.mustangtek.com/images/caution.jpg]70+ 302 Maverick w/MT
    Block 6 Bolt pattern
    Aluminum
    w/ 157 tooth flywheel
    Lever C8OA-7515-A
    ** WILL MAKE A GREAT RESTORATION PIECE TO HELP KEEP YOUR BABY ORIGINAL.
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "
    bmp6570" with a Buy-It-Now of 175.00 or make offer:
    1965-68 Ford Mustang manual bellhousing. For 3 and 4 speeds.
    Will fit 289 and 302 engines. C5DA.
    Look at the pictures good. Missing clutch pivot (on Ebay for around $25), partial piece at bottom is broken off.
    *****SELLING "AS IS" NO RETURN*******
    ***OVERAGE ON SHIPPING WILL BE REFUNDED TO YOUR ACCOUNT***
    1965 1966 1967 1968 ORIGINAL FORD MUSTANG MANUAL 4 SPEED BELLHOUSING 289 C5DA | eBay
  • Here is an Ebay auction for another used C5DA bellhousing with fork by Ebay member "mustangmanbob" with a Buy-It-Now of $245.00 or make offer:
    The engine spacer plate shown in the last picture is NOT part of the listing, just shown for reference. I have several of these. If you need it, it is an extra $35, no shipping cost, if shipped with the bell housing. If you want it, please let me know and I will adjust the listing.
    C5DA-6394-A
    • Official Post
    The listing for this used C5DA bellhousing was ended by the seller February 29, 2024 with the following explanation "This listing was ended by the seller because the item is no longer available".
    • Official Post
    This used C5DA bellhousing "that was no longer available" is back on Ebay again with the same Buy-It-Now of 175.00 or make offer:
    • Official Post
    This used C5DA bellhousing and block plate sold March 6, 2024 on Ebay for $245.00.
    • Official Post
    Here is an Ebay auction for another used C5DA bellhousing with fork by Ebay member "mustangmanbob" with a Buy-It-Now of $270.00 or make offer:
    One of the alignment holes has a chip, that will not have any impact with installation or use.
    C5DA-6394-A
    Aluminum
    Lever C8OA-7515-A
  • This used C5DA bellhousing sold March 12, 2024 on Ebay for $274.99.
  • This used C5DA bellhousing sold March 10, 2024 on Ebay for $175.00.
    This used C5DA bellhousing and block plate sold March 15, 2024 on Ebay for $399.99.
  • This used C5DA bellhousing sold March 20, 2024 on Ebay for $270.00.
  • Here is an Ebay auction for a used C5DA bellhousing by Ebay member "tinpicklespeedshop" with a starting bid of $125.00:
    Manual transmission bellhousing for 1965-1968 Ford 260, 289 Mustang, Falcon, etc.
    There is a small piece of the casting missing on the left dowel pin hole.
    Otherwise good used condition with no visible damage.
    All bolt holes and threads are intact.
    Ford part number- C5DA-6394-A
    Feel free to message with any questions.
    Thanks for looking!
    Bellhousing 1965-1968 Ford 289 260 Mustang Falcon Manual Transmission C5DA-6394A | eBay
  • This used C5DA bellhousing sold March 22, 2024 on Ebay for $128.00 with 2 bids from 2 bidders.
