Used Tri Power Carburetors
  • Here is an Ebay auction for a set of used Tri Power carburetors by Ebay member "highriser427" with a Buy-It-Now of $1,350.00 or make offer:
    USED HOLLEY FORD 3X2 CARBS LISTED AS FITTING 1963 1964 FORD 260 289 ENGINES
    CENTER CARB IS STAMPED C4GF 9510H 2867
    494 1964 SEPT 4TH WEEK
    CARB HAS CORRECT 3673 METERING BLOCK
    THICK ACC PUMP
    PADDLE TYPE ACC PUMP ARM
    5/16 FUEL FITTING
    VENTED FT BOWL WITH STD LEVEL SIGHT PLUG
    58 LI CHOKE COVER
    END CARBS STAMPED
    1 IS STAMPED C4GF 9510J 2868
    2ND IS STAMPED 2868
    392 1963 SEPT 2ND WEEK
    NO FORD PART NUMBER EARLY PRODUCTION CARB BODY
    END CARBS HAVE CORRECT 3563 METERING BLOCKS
    THICK ACC PUMP
    5/16 FUEL FITTING
    PADDLE TYPE ACC PUMP ARMS
    VENTED LOW FLOAT LEVEL SIGHT PLUGS USED ON END CARBS ONLY
    CARBS ARE LISTED IN HOLLEY PARTS BOOK AS FITTING 1963 1964 FORD FAIRLANE FALCON AND COMET CYCLONE MODELS WITH 260 AND 289 ENGINES
    CARBS WERE SOLD AS AN OVER THE COUNTER KIT AND SHOULD WORK ON ANY FORD SMALL BLOCK ENGINE
    CENTER CARB IS 200 CFM AND ENDS ARE 265 CFM ACCORDING TO THE INTERNET
    ALSO HAVE OTHER 2868 BODY WITH DATE CODE 494 AND FORD PART NUMBER BUT IT HAS BEEN GROUND ON SO I USED THE 63 DATE CODE BODY
    HIT THE BUY IT NOW AND I WILL INCLUDE OTHER BODY
    CARBS MUST BE CLEANED AND REBUILT PRIOR TO USE
    CARBS ARE SOLD AS IS
    SORRY NO RETURNS
    https://www.ebay.com/itm/FORD-C4GF-…4EAAOSw6WJd0Dzg
  • Here is an Ebay auction for a set of used Tri Power carburetors by Ebay member "highriser427" with a Buy-It-Now of $1,500.00:
    USED HOLLEY CARBS LISTED AS FITTING 1965 289 ENGINES WITH 3X2 SET UP289 3X2 SETUP WAS SOLD AS AN OVER THE COUNTER ITEM FOR USE ON FORD MUSTANG FALCON SHELBY COBRA FAIRLANE AND MERCURY COUGAR CYCLONE MODELS
    CAN BE USED ON 260 289 AND 302 ENGINES
    CARB IS STAMPED
    C4AF 9510U
    2881
    584
    CARB HAS CORRECT
    3673 METERING BLOCK
    VENTED FRONT BOWL WITH STD FLOAT LEVEL SCREW
    5/16" FUEL FITTING
    PAINTED PADDLE TYPE ACC PUMP ARM
    THICK ACC PUMP
    58LI CHOKE THERMOSTAT
    BLACK CHOKE CAM
    BRASS DIST LINE CONNECTOR
    CARB HAS SOME NEW AND REPLATED HARDWARE
    END CARBS STAMPED
    C4AF 9510V
    2882
    502
    CARBS HAVE CORRECT 4516 METERING BLOCK
    VENTED BOWL WITH LOW FLOAT LEVEL SCREWS ONLY USED ON TRIPOWER END CARBS
    THICK ACC PUMP
    SORRY NO RETURNS
    https://www.ebay.com/itm/HOLLEY-288…pcAAOSw1qVeI5Wj
  • This set of used Tri Power carburetors has had a price reduction to $1,250.00.
  • Here is an Ebay auction for a set of used Tri Power carburetors by Ebay member "brownlee5212" with a starting bid of $0.99:
    Up For Auction are a set of Ford Small Block Tri Power Carbs. Part # C4AF-9510-V FRONT & REAR C4AF-9510-U CENTER. These are from a large Vintage Ford Speed Parts Estate and have been in a basement since the 1970's and other than being dirty they are in great shape.
    https://www.ebay.com/itm/1841587759…=STRK:MEBIDX:IT
    This set of used Tri Power carburetors sold February 13, 2020 on Ebay for $910.00 with 25 bids from 9 bidders.
  • The listing for this set of used Tri Power carburetors was ended by the seller February 16, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This set of used Tri Power carburetors that was "no longer available" is back on Ebay again with no changes:
  • The listing for this set of used Tri Power carburetors has been ended by the seller April 17, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This set of used Tri Power carburetors that was "no longer available" is back on Ebay again with the price going back up tp $1,350.00:
    https://www.ebay.com/itm/1742626369…=STRK:MEWAX:VRI
  • The listing for this set of used Tri Power carburetors was ended by the seller May 22, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This set of used Tri Power carburetors that was "no longer available" is back on Ebay again with a new lower Buy-It-Now of $1,150.00:
    https://www.ebay.com/itm/FORD-C4GF-…5.c100036.m2109
  • The listing for this set of used Tri Power carburetors was ended by the seller August 30, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This set of used Tri Power carburetors that was "no longer available" is back on Ebay again with a new higher Buy-It-Now of $1,500.00 or make offer:
  • This set of used Tri Power carburetors that was "no longer available" is back on Ebay again with a new higher Buy-It-Now of $1,350.00 or make offer:
  • This set of used Tri Power carburetors sold October 22, 2020 on Ebay for $1,500.00.
  • The listing for this set of used Tri Power carburetors was ended by the seller January 10, 2021 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • Here is an Ebay auction for a pair of used Tri Power end carburetors by Ebay member "carbguy01" with a Buy-It-Now of $795.00:
    2 HOLLEY 2868 FORD C4GF 9510 J 260 289 COBRA HIPO TRI POWER 3X2 END CARBS LISTED AS FITTING
    1963 1964 FORD 260 AND 289 ENGINES
    CARBS ARE FOR FRONT AND REAR ENDS OF SETUP
    ONE CARB IS STAMPED
    C4GF 9510J
    2868
    SECOND IS STAMPED
    2868
    393 1963 SEPT 2ND WEEK [ EARLY CARBS WERE NOT STAMPED WITH FORD PART NUMBER ]
    2 CARBS HAVE CORRECT
    THICK ACC PUMP
    5/16 FUEL FITTING
    VENTED LOW FLOAT LEVEL SIGHT PLUGS USED ON TRIPOWER END CARBS ONLY
    ALSO INCLUDED IS MATCHING 494 DATE CODED BODY BUT IS HAS BEEN MODIFIED [SEE PICTURES ]
    HOLLEY 2868 FORD C4GF 9510 J 260 289 SHELBY COBRA HIPO TRI POWER 3X2 END CARBS | eBay
  • This pair of used Tri Power end carburetors sold May 5, 2021 on Enay for $725.00.
  • Here is an Ebay auction for a used Tri Power end carburetor by Ebay member "wa-60" with a Buy-It-Now of $599.99 or make offer:
    Heres a nice holley outboard tripower carburetor. Holley list 2868 with a date of 391 (September 1st week 1963). Ford engineering #c4gf-9510-j. These early carbs were not stamped with ford engineering number. These were manufactured for the 1964 Comet, Fairlane, and Falcon with the 260 and 289 engines.
    Carb is in very nice survivor condition. Definitely taken off early in its life. Plating is nice and still has its original ink stampings. Throttle plates moves, but it's a little stiff. Carb has been sitting a while. Will need to be rebuilt. Rare tripower carb.
    Please look at the pics
    1963 1964 Ford 260 289 Tripower Holley Carb 2868 391 Comet Fairlane Falcon Wow | eBay
