Display MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreHere is an Ebay auction for an NOS C5OZ 12127 E Motorcraft Hipo distributor by Ebay member "mustangmasters428" with a starting bid of $495.00:
Here we have a used Autolite Dual Point Distributor for a 289 High Performance engine, commonly used in Mustangs, Fairlanes, and Cyclones. Standard distributors were equipped with a vacuum advance pod on the side, unlike these high performance units, which offered no vacuum advance.
This original distributor has no extra holes modifications and is in good used working condition. The lobes are crisp to snap both sets of points open as originally designed. No excessive play in the shaft, this unit has no visible signs of gouges, welds, or repairs, and can be used as is, but would certainly be a beautiful candidate for a classic restoration.
It also has a good condition rubber ring on the shaft that is expected to seal tightly without need for replacement and the points and condenser are in excellent condition. This unit has the factory part number of C5OF-12127-E which was for the 65 66 and 67 years, Email for date, please check your date application if you are a show car owner or better.
A great distributor for the daily driver or better, if you own a HiPo equipped Mustang, Fairlane, or Thunderbird this is your distributor! If by chance you are building that HiPo 289 Mustang don't let this auction pass you by!
https://www.ebay.com/itm/264604799353?ul_noapp=true
Note that this is the least desirable distributor as Ford modified single point housings to make these up. This was Fords last ditch effort to supply these distributors before they went obsolete.
This NOS C5OZ 12127 E Motorcraft Hipo distributor received no bids by January 26, 2020 and therefore did NOT sell.
This NOS C5OZ 12127 E Motorcraft Hipo distributor is back on Ebay again with no changes:
https://www.ebay.com/itm/2646608964…em=264660896480
This NOS C5OZ 12127 E Motorcraft Hipo distributor received no bids by March 15, 2020 and therefore did NOT sell.
https://www.ebay.com/itm/2647055797…em=264705579784
This NOS C5OZ 12127 E Motorcraft Hipo distributor received no bids by April 26, 2020 and therefore did NOT sell.
-Fred-This NOS C5OZ 12127 E Motorcraft Hipo distributor is back on Ebay again with no changes:
https://www.ebay.com/itm/3730773902…em=373077390229
This NOS C5OZ 12127 E Motorcraft Hipo distributor received no bids by June 14, 2020 and therefore did NOT sell.
https://www.ebay.com/itm/3731279820…em=373127982042
This NOS C5OZ 12127 E Motorcraft Hipo distributor received no bids by August 2, 2020 and therefore did NOT sell.
https://www.ebay.com/itm/2648569471…em=264856947151
