- New
Display MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreHere is another NOS D1AZ 12A132 A dual point conversion kit on Ebay by the same Ebay seller "mysunshine302" with a starting bid of $120.00 and a Buy-It-Now of $156.00:
You are bidding on a NOS service replacement HiPo dual point mechanical or also know as a dual point centrifugal distributor breaker plate setup. #D1AZ-12A132-A supersede part #C0AF-12152-A. This item has been *obsolete from Ford for over 40 + years!!! ** Ford also used this conversion kit in the Boss 302 Trans Am dual point distributor. This full package kit comes complete as seen fully *Assemble as in the pictures. NOS Motorcraft two piece steel plate & NOS USA made service replacement Motorcraft dual points DP-5 & NOS Ford Motorcraft condenser DC-6 & New stainless steel hardware & New brass jump-bar dual point connector all installed. All looks *New. No corrosion on dual points or condenser. Also including Motorcraft installation paper & the NOS Motorcraft paper package. **Not the 3 Motorcraft boxes** This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E or 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane all centrifugal advance. Also will work *100% to change any of the Ford V8 distributor engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor aluminum housing: FoMoCo & Autolite & Motorcraft. Correct fit for the 1964 to 1973 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with the Ford V8 engines & Ford V8 distributors.
NOS 289 HiPo dual point distributor D1AZ-12A132-A breaker plate Kit 427 428 351 | eBay
This NOS D1AZ 12A132 A dual point conversion kit received no bids by October 7, 2023 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a new higher starting bid of $128.00 and a new higher Buy-It-Now of $166.40:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by October 25, 2023 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a new higher starting bid of $135.00 and a new higher Buy-It-Now of $175.50:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by November 2, 2023 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a new higher starting bid of $150.00 and a new higher Buy-It-Now of $195.00:
The listing for this NOS D1AZ 12A132 A dual point conversion kit was ended by the seller November 10, 2023 with the following explanation "This listing was ended by the seller because the item is no longer available".
This NOS D1AZ 12A132 A dual point conversion kit that was "no longer available" is back on Ebay again with the starting bid of $150.00 and the same Buy-It-Now of $195.00:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by November 26, 2023 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit that was is back on Ebay again with the starting bid of $150.00 and the same Buy-It-Now of $195.00:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by December 3, 2023 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit received no bids by December 10, 2023 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with the same starting bid of $150.00 and the same Buy-It-Now of $195.00:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by December 18, 2023 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a slightly lower starting bid of $135.00 and the same Buy-It-Now of $195.00:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by December 26, 2023 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a new higher starting bid of $155.00 and a new higher Buy-It-Now of $201.50:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by January 2, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a slightly lower starting bid of $150.00 and a slightly lower Buy-It-Now of $195.00:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by January 10, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit received no bids by January 17, 2024 and therefore did NOT sell.
The listing for this NOS D1AZ 12A132 A dual point conversion kit was ended by the seller January 18, 2024 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this NOS D1AZ 12A132 A dual point conversion kit was ended by the seller January 22, 2024 with the following explanation "This listing was ended by the seller because the item is no longer available".
This NOS D1AZ 12A132 A dual point conversion kit received no bids by February 14, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit received no bids by February 26, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a new lower starting bid of $140.00 and a new lower Buy-It-Now of $182.00:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by March 5, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a new lower starting bid of $125.00 and a new lower Buy-It-Now of $162.50:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by March 12, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with the same starting bid of $125.00 and the same Buy-It-Now of $162.50:
This NOS D1AZ 12A132 A dual point conversion kit received no bids by March 19, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit received no bids by March 27, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit received no bids by April 3, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit received no bids by April 10, 2024 and therefore did NOT sell.
This NOS D1AZ 12A132 A dual point conversion kit received no bids by April 17, 2024 and therefore did NOT sell.
