Used Autolite Hipo Dual Point Distributor
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "billbinega-0" with a starting bid of $350.00 and a Buy-It-Now of $600.00:
    I have up for bid is an AUTOLITE dual point distributor for a Ford 289 High Performance engine. These 289 Hi Po distributors were recommended by Ford to use in Boss 302 engines in Hi Performance and racing applications, per Ford Autolite catalog from back in the day. These can be used in small block 260, 289 and 302 engines, if you want to get rid of the vacuum advance off your racing engines. This distributor looks very good, it would need cleaned up and detailed. Still has Autolite points, and even the condenser appears to be an Autolite. The distributor gear looks very good, minumin wear. if I had to guess I would say low miles. If I was to use it I would clean it up good, and replace the points, and condenser, but a complete rebuild would also be a good idea. This is an Autolite Distributor, with a date code of 0H9 which would be August 9, 1970 which makes this a replacement distributor. I bought this distributor years ago, from a guy who claimed it came out of a Boss 302 Mustang, where he installed an original Boss 302 distributor. Don't be confused by the later model 289 HI PO distributors, that have the advance hole plugged. this one is like the original, there was NO hole for the vacuum advance. This looks like and will perform like the original distributor. With that being said, there are 2 other Autolite Distributors, like this one on Ebay, both have a buy it now of at least $740. Another one sold on November 26 for $725. One of those late model replacements with the distributor hole plugged, just sold for $325. There for i will have a starting bid of $350. I will have a buy it now of $600. I will ship in a USUP Flat rate box with insurance to protect both of Our interest. I will set shipping, and insurance at $25
    C5OF 12127 E 0H9
    AUTOLITE 289 HI PO DUAL POINTS DISTRIBUTOR BOSS 302 FORD K CODE SHELBY MUSTANG | eBay
    C5OF 12127 E 0H9
    The listing for this used Autolite Hipo distributor was ended by the seller December 19, 2023 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "2014_tures" with a starting bid of $475.00 and a Buy-It-Now of $630.00:
    Vintage FORD Autolite 289 HIPO K-Code distributor C5AF-12127-E Dual Points Mechanical Advance. Concourse Correct all SB Fords from 1965 --1967.
    HiPo-289 C5AF-12127-E Build date 1H25 K-Code Autolite FORD Distributor | eBay
    This used Autolite Hipo distributor sold January 10, 2024 on Ebay for $630.00.
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "mustangmasters428" with a starting bid of $495.00:
    Here we have a good used C5OE FoMoCo Dual Point Distributor for a 289 High Performance engine, commonly used in Mustangs, Fairlane's, and Cyclones with these special 271 horsepower motors. Standard distributors were equipped with a vacuum advance pod on the side. These stock units had only 1 set of points unlike these high performance units which used 2 sets to get a hotter spark for increased performance. They also had a sleek distinctive look with NO vacuum advance.
    This original distributor has some minor cosmetic issues although there are no extra holes or any modifications. You will find it is in good used working condition although we do suggest you use your judgement before installing. The lobes are crisp to snap both sets of points open as designed. No excessive play in the shaft, this unit has no visible signs of gouges, welds, or repairs. This piece can be used as is for a survivor car or could be a perfect candidate for a K code classic restoration.
    This unit has the factory part number of C5OF-12127-E which was for the 65 66 models with a stamped date of 0F10 (Just in 1965 dated distributor as well as whole motor and coupe with original 9 inch rear.) Should this not be correct for your car we also have several other factory dual points available. Please check your application and if you are a high end show car owner please realize you might give extra time to function and or detail to meet your higher standards.
    A great distributor for that buyer completing his motor whether it be on an engine stand or in a GT Fastback, even a Shelby clone. It's the real deal for those who own a 289 HiPo equipped Mustang or Fairlane. This is your distributor, don't miss out!
    289 HiPo Shelby Mustang FoMoCo Dual Point Distributor C5OF 12127 E Have 65 dated | eBay
  • This used Autolite Hipo distributor received no bids by January 14, 2024 and therefore did NOT sell.
  • Here is an Ebay auction for a remanufactured Autolite Hipo distributor by Ebay member "automotivetoolsandparts" with a Buy-It-Now of $1,250.00:
    This is a very nice rebuilt Autolite distributor. Dated 6J15 for a hipo or Shelby, even has a new old stock Ford gear on it. All done with good quality parts. Please feel free to ask any questions
    FORD MUSTANG SHELBY 289 HI-PO C5OF-12127-E DUAL POINT DISTRIBUTOR K CODE 6J15 | eBay
  • Here is an Ebay auction for a remanufactured Autolite Hipo distributor by Ebay member "automotivetoolsandparts" with a Buy-It-Now of $1,200.00:
    This is a very nice rebuilt Autolite distributor. Dated 6M12 for a 67 hipo or shelby. All done with good quality parts. Please feel free to ask any questions
    FORD MUSTANG SHELBY 289 HI-PO C5OF-12127-E DUAL POINT DISTRIBUTOR K CODE 6M12 | eBay
  • Here is an Ebay auction for a remanufactured Autolite Hipo distributor and NOS FoMoCo cap by Ebay member "260alpine" with a Buy-It-Now of $650.00 or make offer:
    This Hipo 289 "K" code distributor 12127 E was completely disassembled inspected and cleaned. New points, power lead wire and correct screws. Comes with NOS FOMOCO CAP.
    Ford Mustang, Shelby HiPo 289 K-Code Dual Point Distributor C5OF-12127-E | eBay
    This used Autolite Hipo distributor sold February 23, 2024 on Ebay for $650.00.
  • This used Autolite Hipo distributor sold February 23, 2024 on Ebay for $630.00.
    • Official Post
    This used Autolite Hipo distributor is back on Ebay again with the same starting bid of $495.00:
  • This used Autolite Hipo distributor received no bids by March 10, 2024 and therefore did NOT sell.
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "ericksonnf50" with a Buy-It-Now of $875.00 or make offer:
    Mustang, Fairlane, Shelby Hi Po K-Code Distributor C5OF-12127-E. Date code 9K23
    This used Autolite Hipo distributor sold March 28, 2024 on Ebay for $775.00.
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "natesclassiccars" with a Buy-It-Now of $700.00:
    For Sale is an Original 1965 - 1967 Ford Mustang 289 HiPo Autolite Distributor. Dated 9H9. Good Original Condition and Fit. Great for Restorations and Projects. Feel Free to Ask Questions.
    Original 1965 1966 1967 Ford Mustang Shelby 289 HiPo Autolite Distributor | eBay
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "bnmtr-24" with a Buy-It-Now of $750.00 or make offer:
    Distributor for 289 mustang. C50f-12127-e
    ford mustang shelby 289 hi po c50f-12127 dual point distributor k code autolite | eBay
    • Official Post
    • Official Post
    This used Autolite Hipo distributor sold May 11, 2024 on Ebay for $700.00.
    • Official Post
    This used Autolite Hipo distributor received no bids by May 12, 2024 and therefore did NOT sell.
    • Official Post
    This used Autolite Hipo distributor sold May 24, 2024 on Ebay for $650.00.
