Used Autolite Hipo Dual Point Distributor
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "mustangmasters428" with a starting bid of $450.00:
    [size=2][size=2]Here we have a good used C5OE FoMoCo Dual Point Distributor for a 289 High Performance engine, commonly used in Mustangs, Fairlane's, and Cyclones with these special 271 horsepower motors. Standard distributors were equipped with a vacuum advance pod on the side. These stock units had only 1 set of points unlike these high performance units which used 2 sets to get a hotter spark for increased performance. They also had a sleek distinctive look with NO vacuum advance.[/size][/size]
    [size=2][size=2]This original distributor has some minor cosmetic issues although there are no extra holes or any modifications. You will find it is in good used working condition although we do suggest you use your judgement before installing. The lobes are crisp to snap both sets of points open as designed. No excessive play in the shaft, this unit has no visible signs of gouges, welds, or repairs. This piece can be used as is for a survivor car or could be a perfect candidate for a K code classic restoration.[/size][/size]
    [size=2][size=2]This unit has the factory part number of C5OF-12127-E which was for the 65 66 models with a stamped date of 0F10. This FOMOCO part is a true factory original piece verses the later version Motorcraft replacement. Should this not work for you we also have several other factory dual points available. Please check your application and if you are a high end show car owner please realize you might give extra time to function and or detail to meet your higher standards .[/size][/size]
    [size=2] [size=2]A[/size] great distributor for that buyer completing his motor whether it be on a engine stand or in a GT Fastback, even a Shelby clone. Its the real deal for you who own a HiPo 289 equipped Mustang or Fairlane this is your distributor! If by any chance you're are building that HiPo 289 don't miss out! [/size]
    https://www.ebay.com/itm/Shelby-HiP…sacAAOSw7j5bAi5-
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "perrys3" with a Buy-It-Now of $650.00:
    Just a 1965 Mustang HIPO distributor.
    Check the date code .
    Good for restoration. Thanks
    https://www.ebay.com/itm/1965-Ford-…1.c100167.m2940
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "valhallastudio" with a Buy-It-Now of $579.99:
    Autolite distributor, January 22 1970 date code.
    See pictures for condition.
    See my other Ford parts listed.
    https://www.ebay.com/itm/AUTOLITE-M…1.c100167.m2940
  • This used Autolite Hipo distributor received no bids by September 29, 2019 and therefore did NOT sell.
  • Quote from C6ZZKGT
    The Buy-It-Now on this distributor has been lowered to $525.00.
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "clausenk-93" with a Buy-It-Now of $500.00:
    Ford Autolite HiPo 289-302 Distributor. Over the Counter Performance item.Dual Point Mechanical Advance restored, housing tumbled machined,new bushing installed, parts replated new Motorcraft points rotor and correct cap. Drive gear in but not pinned if buyer is using a bronze gear
    https://www.ebay.com/itm/Ford-Autol…P0AAOSwljFdq7fd
  • This used Autolite Hipo distributor sold January 29, 2020 on Ebay for $525.00.
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "mercuryman67" with a starting bid of $100.00:
    Hi Po distributor 289 Mustang ,Fairlane, free shipping lower 48. Condition is Used. Shipped with USPS Parcel Select Ground.
    https://www.ebay.com/itm/Hi-Po-dist…ywAAOSw09ZePC6G
    The Buy-It-Now price on this distributor has been lowered to $549.99.
    This used Autolite Hipo distributor sold February 13, 2020 for $167.50 with 9 bids from 5 bidders.
  • Even though this distributor did not bring a lot of money, I am surprised by the amount of activity for a distributor that has no real original application as it is purely a replacement unit.
    This used Autolite Hipo distributor sold February 18, 2020 for $600.00.
  • I am surprised by the high price paid for a distributor that has no real original application as it is purely a replacement unit.
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "mustangs-n-musclecars " with a Buy-It-Now of $750.00:
    Up for auction is a very rare 289 hi po dual point distributor. This was the shop tips version they suggested replacing your stock Boss 302 distributor with. This unit would be a great candidate for such an application with it's Date code - 0F30 = June 30, 1970. Very nice shape - see all pictures. Winning bidder is responsible for shipping costs. Thank you for looking at our auction!
    https://www.ebay.com/itm/289-HiPo-F…eoAAOSwEPReWwjQ
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "gwpford" with a Buy-It-Now of $299.99:
    Here is a factory ford AuToLite duel point distributor cast C5OF-E,it does spin over with no play and is being sold as a core for restoration you are getting what is in picture, thanks for looking.
    https://www.ebay.com/itm/1964-65-66…-sAAOSwaSheMi3A
    • Official Post
    Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "bob429scj" with a starting bid of $295.00:
    Up for bid is this ORIGINAL FACTORY FORD C5OF-12127-E FOMOCO DUAL POINT DISTRIBUTOR with DATE 9H9, Aug 9 1969. FITS FORD SMALL BLOCK HI-PO 289 and is a FACTORY REPLACE UNIT for THE LATER BOSS 302 ENGINES ,It is in Nice condition. Shaft moves freely Gear shows very little wear. It has a new set of BLUE STREAK points installed. The lead wire to the coil should be replaced. Up for 295.00 with NO RESERVE. Shipping will be free within the continental US. All Items are sold as is with no returns. Thanks for looking and please view our other items.
    https://www.ebay.com/itm/FORD-C5OF-…jQAAOSwTSperIie
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "bob429scj" with a starting bid of $295.00:
    This used Autolite Hipo distributor received no bids by May 8, 2020 and therefore did NOT sell.
  • This used Autolite Hipo distributor is back on Ebay again with a new slightly lower starting bid of $275.00:
    https://www.ebay.com/itm/2935777605…em=293577760588
  • This used Autolite Hipo distributor received no bids by May 17, 2020 and therefore did NOT sell.
  • The listing for this used Autolite Hipo distributor was ended by the seller May 28, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
