Used Autolite Hipo Dual Point Distributor
    • Official Post
    This used Autolite Hipo distributor that is "no longer available" is back on Ebay again with no changes:
    https://www.ebay.com/itm/AUTOLITE-M…5.c100036.m2109
    • Official Post
    Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "bob429scj" with a starting bid of $275.00:
    Because the swap meet is closed, I have Up for bid is this ORIGINAL FACTORY FORD C5OF-12127-E FORD AUTOLITE DUAL POINT DISTRIBUTOR with DATE 9H9, Aug 9 1969. FITS FORD SMALL BLOCK HI-PO 289 and is a FACTORY REPLACE UNIT for THE LATER BOSS 302 ENGINES ,It is in Nice condition. Shaft moves freely Gear shows very little wear. It has a new set of BLUE STREAK points installed. The lead wire to the coil should be replaced. Up for 275.00 with NO RESERVE. Shipping will be free within the continental US. All Items are sold as is with no returns. Thanks for looking and please view our other items.
    https://www.ebay.com/itm/FORD-C5OF-…jQAAOSwTSperIie
    • Official Post
    This used Autolite Hipo distributor sold June 14, 2020 on Ebay for $275.00.
    • Official Post
    Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "gwpford" with a Buy-It-Now of $299.99:
    Here is a factory ford AuToLite duel point distributor cast C5OF-E,it does spin over with no play and is being sold as a core for restoration you are getting what is in picture, thanks for looking.
    https://www.ebay.com/itm/1964-65-66…-sAAOSwaSheMi3A
    This used Autolite Hipo distributor sold June 24, 2020 on Ebay for $269.99.
    • Official Post
    Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "hertz1966" with a Buy-It-Now of $375.00 or make offer:
    289 302 Ford "Hi-Po" High Performance Dual Point Distributor.
    This is a ford 289 hipo dual point distributor. It is used and has been sitting on the shelf for 20 years.
    Part number: C50F-12127
    Part Number on housing shaft. C50F-12131-B
    https://www.ebay.com/itm/1965-66-67…yUAAOSwDtRe9Xey
  • This used Autolite Hipo distributor sold August 28, 2020 on Ebay for $375.00.
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "njpicker" with a starting bid of $129.99:
    You are bidding on an original Vintage AUTOLITE Hi-Po Dual Point Mechanical Advance Distributor Ford Part No. C50F12127E selling AS IS. The number stamped on the upper base just below the cap is C50F12127E, date code 9K23 (10/23/69). The number cast on the lower stem is C50F12131B.
    This distributor has been in dry storage on a shelf in the same race garage since the 1970’s & recently discovered. It appears to be in very good overall condition with the shaft & mechanism moving freely, but it has NOT been tested. While it MAY work fine (don’t know), it is being offered for PARTS or RESTORATION / REBUILD ONLY AS IS with no warranty or guarantee. Distributor cap NOT included.
    I know NOTHING about this item or what specific car it was removed from. Based on some research & after checking with a very knowledgeable Ford restorer & racer, I was told that this distributor is for 1965-67 289 Hi-Po Mustang & Shelby GT 350, Boss 302 & likely other years & applications based on the October 1969 date code. However, I will rely on those way more knowledgeable viewing this listing to identify & determine specific application(s). Low opening bid in hopes that someone can identify & utilize.
    https://www.ebay.com/itm/274493900733?ul_noapp=true
  • The listing for this used Autolite Hipo distributor was ended by the seller September 16, 2020 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • This used Autolite Hipo distributor sold September 18, 2020 on Ebay for $274.95.
  • Here is an Ebay auction for a restored Autolite Hipo distributor by Ebay member "mysunshine302 " with a starting bid of $475.00 and a Buy-It-Now of $625.00:
    I am selling off some of my Ford parts, that I have been collecting for over the last 45+ years. Time to pass on hard to find Ford obsolete parts too the up coming younger generations to use.
    You are bidding on a original 289 HiPo Autolite housing (K) code dual point distributor. This is a correct Ford 289 HiPo dual point distributor totally restored. Ready to install and Rev!!!!! 8000 RPM !!!!! Part number on housing C5OF-12127-E date code 5K23. Correct for the early 1966 (K) code 289 HiPo engine in the Shelby GT350 & AC Cobra & Ford Mustang GT & Ford Fairlane GT & Ford Falcon Sprint & Mercury Comet & Mercury Cougar XR7 & Mercury Cyclone & Spoiler. This is a great find of a Ford 289 HiPo dual point distributor. Great if your purchase a HiPo car & did not come with a 289 HiPo distributor or building a HiPo engine to sell. Comes complete as in all the pictures with***All NOS Motorcraft points & NOS Motorcraft condenser & original restored dual point breaker plate & New primary wire & New screw & hardware & New shaft bushing. Also a original NOS black Motorcraft cap & NOS Motorcraft black rotor. Still has a nice looking like original aluminum patina & machine finish.**This aluminum Autolite housing is **NOT Painted** Like most out there on eBay!
    https://www.ebay.com/itm/363114786409?ul_noapp=true
    The listing for this used Autolite Hipo distributor was ended by the seller September 26, 2020 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • This rebuilt Autolite Hipo distributor is back on Ebay again with a starting bid of $495.00 and a Buy-It-Now of $645.00:
    https://www.ebay.com/itm/363131797746?ul_noapp=true
  • This rebuilt Autolite Hipo distributor sold October 6, 2020 on Ebay for $645.00.
  • Here is an Ebay auction for a restored Autolite Hipo distributor by Ebay member "whatsur*" with a starting bid of $400.00 and a Buy-It-Now of $550.00:
    Ford 289 Hipo K-code Shelby, Cobra, Dual Point Distributor C50F-12127. Condition is "Used".
    This distributor comes with a concours quality reproduction distributor lead. It has drive gear attached, rotor, points, and condenser. Those last three should probably be replaced.
    I've priced this less than the other Hipo distributors for sale here.
    I'm not a business so shipping will be extra. Thank you for your time.
    Ford 289 Hipo K-code Shelby, Cobra, Dual Point Distributor C50F-12127 | eBay
    This restored Autolite Hipo distributor sold December 9, 2020 on Ebay for $350.00 with 3 bids from 2 bidders.
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "lovemy64tbird" with a Buy-It-Now of $750.00 or make offer:
    Here's a excellent C50F-12127-E Autolite Dual Point Distributor. Based on http://www.Mustangtek.com website (I included a photo of the years/vehicle usages)
    15spline gear is perfect and spins freely as necessary
    A rare original Autolite part for your 289 HIPO or 1965-1967 Shelby GT350
    I added a new Motorcraft C0DF-12216-A / AUTOLITE PART#: DW-10 coil cable
    Let me know if you have any questions...
    1965-1967 Shelby 350/ HIPO 289 Autolite Dual Point Distributor | eBay
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "1212robertd" with a Buy-It-Now of $200.00:
    Ford 289HiPo dual point Motor craft Distributor #C50F-12127-E. Condition is "Used". Shipped with USPS Parcel Select Ground.
    Ford 289HiPo dual point Motor craft Distributor #C50F-12127-E | eBay
    This used Autolite Hipo distributor sold February 11, 2021 on Ebay for $200.00.
  • Here is an Ebay auction for a restored Autolite Hipo distributor by Ebay member "mysunshine302 " with a starting bid of $475.00:
    ***Please take your time and read full description***
    You are bidding on a professional *totally restored original service replacement Autolite housing dual point distributor # C5OF-12127-E. Comes complete installed with all NOS Ford Motorcraft parts & and hardward. This is a correct 289 HiPo (K) code Autolite housing dual point distributor for the 1964 & 1967 Ford Mustang GT & Cougar XR7 & Ford Falcon & Fairlane GT & Mercury Comet. Part number on Autolite aluminum distributor housing C5OF-12127-E with date code 9M18. Still looks to have nice factory machine & aluminum patina finish.
    Ready to install and rev!!!!!!
    ****Shipping fee also includes ***(FREE insurance in the USA)*****
    ***Will ship out/side of the USA.***
    ***Shipping cost will be added for purchases out side of the USA. ***
    *** I can post a Buy It Now if it can help you.**** Or just bid freely! ***
    *** Please look at all the pictures & ask all questions before auction ends! ***
    ***Please view all my other Ford parts***
    ****Remember Made & Restored in the USA Ford parts give the Best performance***
    289 HiPo dual point distributor K code C5OF-12127-E Mustang, Cougra, Falcon | eBay
  • Here is an Ebay auction for a used Autolite Hipo distributor by Ebay member "lovemy64tbird " with a Buy-It-Now of $625.00:
    Here's a excellent C50F-12127-E Autolite Dual Point Distributor. Based on http://www.Mustangtek.com website (I included a photo of the years/vehicle usages) 15 spline gear is perfect and spins freely as necessary A rare original Autolite part for your 289 HIPO or 1965-1967 Shelby GT350 I added a new Motorcraft C0DF-12216-A / AUTOLITE PART#: DW-10 coil cable Let me know if you have any questions...
    Autolite 1965-1967 Shelby/HIPO Dual Point Distributor | eBay
