Used 289 Carburetor Spacer Plate
  • This used Hipo 289 carburetor spacer is back on Ebay again with no changes:
    https://www.ebay.com/itm/1537478876…em=153747887694
  • Here is an Ebay auction for a used Hipo 289 carburetor spacer by Ebay member "fordmanted2b2b" with a Buy-It-Now of $74.99:
    OEM ORIGINAL FORD 4V ALUM. CARB SPACER -1" THICK AND USED ON ALL FORD/HOLLEY REGULAR BASES. HAVE SEVERAL IN GOOD SHAPE. STORED FOR MANY YEARS AND SOLD A LOT WHEN NEW . KEEPS FUEL COOLER DUE TO HOLLOW SPACE IN HOT WEATHER WITH THICK GASKETS AND LONGER STUDS. STAMPED C40E-9A589-E INSIDE. PVC HOLE ON SOME AND NO HOLE ON OTHERS. THANKS FOR LOOKING TAKE CARE AND GOD BLESS fordmanted2b2b FREE SHIPPING
    https://www.ebay.com/itm/OEM-Ford-C…~YAAOSwMg5cKKGo
  • Quote from C6ZZKGT
    Here is an Ebay auction for a used Hipo 289 carburetor spacer with PCV by Ebay member "magmustangs" with a starting bid of $99.00:
    1964-1969 Ford Mustang, GT, GTA, GT/CS, Mach 1, Grande, Shelby GT350, Falcon, Fairlane, Torino, Ranchero, Mercury Cougar, XR7, Eliminator, Montego, Comet, Cyclone. ORIGINAL 4V CARBURETOR SPACER For 289-HIPO-302-351W Engine. 1" HEIGHT. This is an ORIGINAL FORD PART. Casting Number C4OE-9A589-A and (FoMoCo). Removed from a 65 Mustang GT Fastback with 289 4V Motor. This Spacer is in Great Original Condition. It is Clean and Straight. Has a Natural Metal Finish and Looks Great. Smooth Gasket Surfaces. No heavy Build-Up on the inside. Has a Good PCV Port Tube. Not clogged. No Cracks. No rust or corrosion. Overall, this is a Great Original 4V Carburetor Spacer. Please email with questions. 100719-2 WE HAVE AN EBAY STORE WITH THOUSANDS OF ORIGINAL FORD PARTS. CHECK IT OUT.
    https://www.ebay.com/itm/1964-1965-…rIAAOSw1Txdm6uf
    This used Hipo 289 carburetor spacer received no bids by November 4, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1537110679…em=153711067985
    This used Hipo 289 carburetor spacer received no bids by November 11, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1537216302…em=153721630264
    This used Hipo 289 carburetor spacer received no bids by November 18, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1639508294…em=163950829463
    This used Hipo 289 carburetor spacer received no bids by November 25, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1537389607…em=153738960714
    This used Hipo 289 carburetor spacer received no bids by December 2, 2019 and therefore did NOT sell.
    This used Hipo 289 carburetor spacer received no bids by December 9, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1537564611…em=153756461192
  • Here is an Ebay auction for a used Hipo 289 carburetor spacer by Ebay member "smallbford" with a Buy-It-Now of $80.00:
    This item is a ford v8 4bbl aluminum factory oem carburetor spacer plate. This spacer was factory on most 289 and 302 4v engines 1963 - 1968 including mustangs, it was also used on the 1969 mustang gt350 351w and the 1969 cougar 351w.
    https://www.ebay.com/itm/1911570278…e=STRK:MEWAX:IT
  • Here is an Ebay auction for a used Hipo 289 carburetor spacer by Ebay member "mustangfent" with a Buy-It-Now of $50.00:
    Ford Mustang Originial Carburetor Spacer Plate, Square Flange 260 289 351C 429. Condition is Used. Shipped with USPS Parcel Select Ground. C4OZ
    https://www.ebay.com/itm/Ford-Musta…xQAAOSwE9Jc23Hj
    Here is an Ebay auction for a used Hipo 289 carburetor spacer without PCV by Ebay member "welbury3028" with a Buy-It-Now of $135.00:
    SB Ford Mercury Lester 4V Carburetor Spacer 289 302 Falcon Mustang Cougar Comet. Condition is Used. Shipped with USPS Priority Mail.
    https://www.ebay.com/itm/SB-Ford-Me…hIAAOSw1~tdnLaF
    This used Hipo 289 carburetor spacer without PCV sold December 16, 2019 on Ebay for $135.00.
    [size=4]1964-1969 Ford Mustang, GT, GTA, GT/CS, Mach 1, Grande, Shelby GT350, Falcon, Fairlane, Torino, Ranchero, Mercury Cougar, XR7, Eliminator, Montego, Comet, Cyclone. ORIGINAL 4V CARBURETOR SPACER For 289-HIPO-302-351W Engine. 1" HEIGHT. This is an ORIGINAL FORD PART. Casting Number C4OE-9A589-A and (FoMoCo). Removed from a 65 Mustang GT Fastback with 289 4V Motor. This Spacer is in Great Original Condition. It is Clean and Straight. Has a Natural Metal Finish and Looks Great. Smooth Gasket Surfaces. No heavy Build-Up on the inside. Has a Good PCV Port Tube. Not clogged. No Cracks. No rust or corrosion. Overall, this is a Great Original 4V Carburetor Spacer. Please email with questions. 100719-2 WE HAVE AN EBAY STORE WITH THOUSANDS OF ORIGINAL FORD PARTS. CHECK IT OUT.[/size]
    [size=2]https://www.ebay.com/itm/1964-1965-…rIAAOSw1Txdm6uf[/size]
    This used Hipo 289 carburetor spacer received no bids by December 16, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1537648477…em=153764847713
    This used Hipo 289 carburetor spacer received no bids by December 23, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1537729842…em=153772984290
    This used Hipo 289 carburetor spacer received no bids by December 30, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/1537810657…em=153781065772
    This used Hipo 289 carburetor spacer received no bids by January 6, 2020 and therefore did NOT sell.
    Edited once, last by C6ZZKGT (January 14, 2020 at 11:39 AM).
    https://www.ebay.com/itm/1537880219…em=153788021946
    Edited once, last by C6ZZKGT (January 14, 2020 at 11:37 AM).
    This used Hipo 289 carburetor spacer received no bids by January 13, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/1537957810…em=153795781031
  • Here is an Ebay auction for a used Hipo 289 carburetor spacer without PCV by Ebay member "1943ninny" with a starting bid of $49.99:
    ORIGINAL 1964 1965 1966 MUSTANG SHELBY GT 350 289 HIPO CARB SPACER NO VAC PORT. Condition is Used. Shipped with USPS First Class Package.
    https://www.ebay.com/itm/ORIGINAL-1…yoAAOSwpXBeHP9s
    This used Hipo 289 carburetor spacer without PCV received no bids by January 20, 2020 and therefore did NOT sell.
  • This used Hipo 289 carburetor spacer without PCV is back on Ebay again with no changes:
    https://www.ebay.com/itm/2742170623…em=274217062320
