C4OE 8505 A Rebuilt Hipo Water Pump
  • Here is an Ebay auction for a rebuilt C4OE 8505 A Hipo water pump by Ebay member "289special" with a Buy-It-Now of $550.00:
    This is one Ford remanufactured water pump. Casting number C4OE-8505-A. For 1963 1964 Ford 289 Hipo, Cobra, Fairlane. Six vane. Part number on the vane 30574. Came from a Ford dealership. The pump has a texture to it. Do your homework. Know your part. Ask questions. Buyer pays $30.00 shipping and handling 48 United States only.
    https://www.ebay.com/itm/1963-1964-…PucAAOSwUvVdBV8-
  • Quote from C6ZZKGT
    The auction for this rebuilt C4OE 8505 A Hipo water pump was ended by the seller June 14, 2019 with the following explanation "This listing was ended by the seller because the item is no longer available".
    This rebuilt C4OE 8505 A Hipo water pump is back on Ebay again with a new lower Buy-It-Now of $350 or make offer:
    https://www.ebay.com/itm/2644434257…=STRK:MEWAX:VRI
    The auction for this rebuilt C4OE 8505 A Hipo water pump was ended by the seller October 25, 2019 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This rebuilt C4OE 8505 A Hipo water pump is back on Ebay again with a new lower Buy-It-Now of $150:
    https://www.ebay.com/itm/2645436664…=STRK:MEWAX:VRI
    This water pump is for Hipo 289 engines with a generator rather than an alternator which means that it also fits 64 1/2 Hipo 289 Mustangs.
  • This rebuilt C4OE 8505 A Hipo water pump sold November 24, 2019 for $150.00.
  • Here is an Ebay auction for a rebuilt C4OE 8505 A Hipo water pump by Ebay member "welbury3028" with a Buy-It-Now of $285.00:
    1964 Ford Mustang & Fairlane 289 Water Pump C40E-8505-A Fomoco HEFFIELO.
    Remanufactured old stock. Has surface rust on bottom as seen in photos!
    https://www.ebay.com/itm/1964-Ford-…5.c100012.m1985
  • The auction for this rebuilt C4OE 8505 A Hipo water pump was ended by the seller June 6, 2020 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • This rebuilt C4OE 8505 A Hipo water pump is back on Ebay again with a new lower Buy-It-Now of $250:
    https://www.ebay.com/itm/1964-Ford-…=p2047675.l2557
  • This rebuilt C4OE 8505 A Hipo water pump sold June 6, 2020 for $250.00.
  • Here is an Ebay auction for a rebuilt C4OE 8505 A Hipo water pump by Ebay member "purefomoco" with a starting bid of $200.00:
    Item shown for bid is a really nice late 6 (C3OZ) or early 64 289 Hi Po waterpump. It has the three holes, 6 vanes and little under 4 inch empellor dia. and the cast date i believe to be Oct 1963. Its a Ford rebuilt and i am thinking it was boxed as a (C5OZ) 1965 year model car. Bid with confidence,,,,,,,Thanks Pete
    1963/64 Ford Fairlane Comet 289 HiPo Water Pump Factory Rebuilt | eBay
    This rebuilt C4OE 8505 A Hipo water pump sold May12, 2022 for $276.00 with 9 bids from 2 bidders.
  • Here is an Ebay auction for a rebuilt C4OE 8505 A Hipo water pump by Ebay member "2ndgenautoparts" with a Buy-It-Now of $425.00:
    Description
    Up for sale is a professionally water pump for the following applications:
    1963-64 Ford Fairlane 289ci 4.7L V8 engines.
    1964-1/2 Ford Mustang 289ci 4.7L V8 engines.
    1964 Mercury 289ci 4.7L V8 engines.
    The OEM casting is C4OE-8505-A and the date is May 64 (64 5-dots).
    This is an aluminum body pump without the back plate
    This is an original HI-PO 6 curved-fin impeller.
    NOTE: This pump is only for the vehicles that still have a generator not an alternator.
    This is a professionally rebuilt Ford water pump comes with a 90 day warranty and a new mounting gasket.
    NOTE: There is a $40.00 refundable core deposit included in the price upon the return of your old rebuildable original pump.
    If you have any questions regarding this item contact me by email.
    1963-64 Ford Mustang Mercury Comet 289 V8 rebuilt HI-PO water pump C4OE-8505A | eBay
  • This rebuilt C4OE 8505 A Hipo water pump sold August 16, 2022 for $425.00.
  • This rebuilt C4OE 8505 A Hipo water pump sold November 16, 2022 for $425.00.
  • Here is another Ebay auction for a rebuilt C4OE 8505 A Hipo water pump by Ebay member "2ndgenautoparts" with a Buy-It-Now of $425.00:
    Description
    The OEM casting is C4OE-8505-A and the date is May 64 (11-dots).
    I can't verify the 63 or the 64 inside the circle.
    1963-64 Ford Mustang Mercury Comet 289 V8 rebuilt HI-PO water pump C4OE-8505A-11 | eBay
  • Here is an Ebay auction for a rebuilt C4OE 8505 A Hipo water pump by Ebay member "marvelouspartsoforegon" with a Buy-It-Now of $317.63:
    Up for Sale:
    Restored Original Water Pump
    Applications:
    1963-64 Ford Fairlane with 289ci "K" code engines
    1964-1/2 Mustang with 289ci "K" code engines
    1963-64 Mercury Comet with 289ci "K" code engines
    Plus many others, use compatibility chart for proper fitment.
    This will fit other makes and models that came with the 289ci "K" code engines.
    Specifications:
    Casting Number: C4OE-8505-A
    Date Code: 4-65
    Warranty: 180 day
    Note: This has a correct new aftermarket HI-PO 6 curved fin impeller.
    This is for vehicles with a generator not an alternator.
    New mounting gasket included with purchase
    The quality of our rebuilds will speak for themselves, these water pumps have been through a meticulous process to make sure they meet or exceed industry standards.
    New bearings and seals were used to restore this to OE standards.
    This is a professionally rebuilt water pump by our family business with over 50 years of rebuilding experience.
    Rebuilt 1962-64 Ford Fairlane Mustang water pump C4OE-8505-A 289ci "K" code HIPO | eBay
  • This rebuilt C4OE 8505 A Hipo water pump sold August 14, 2023 for $317.63.
  • This rebuilt C4OE 8505 A Hipo water pump sold September 14, 2023 for $317.63.
