Used C8ZE Replacement Harmonic Balancer
  • Here is an Ebay auction for a used C8ZE replacement Hipo harmonic balancer by Ebay member "valhallastudio" with a Buy-It-Now of $244.95:
    HIPO balancer with good rubber, good threads and no Hammer marks, see pictures for condition.
    https://www.ebay.com/itm/OEM-HIPO-2…AAAAOSwPXJcnYd1
    HiPo 289 Harmonic Balancer, see pictures for condition.
    https://www.ebay.com/itm/C8ZE-A-HiP…SQAAOSwkYpcnXAO
    https://www.ebay.com/itm/HIPO-289-H…JUAAOSwxbFcos3D
    This used C8ZE replacement Hipo harmonic balancer received no bids by April 27, 2019 and therefore did NOT sell.
  • This used C8ZE replacement Hipo harmonic balancer received no bids by April 27, 2019 and therefore did NOT sell.
    This used C8ZE replacement Hipo harmonic balancer is back on Ebay again with no changes:
    https://www.ebay.com/itm/2332148149…em=233214814945
  • Here is an Ebay auction for a used C8ZE replacement Hipo harmonic balancer by Ebay member "jzram" with a Buy-It-Now of $200.00:
    C8ZE-A HiPo 289 Harmonic Balancer. Condition is Used.
    Nice used HiPo 289 Harmonic Balancer 65’-67’ for use with 1M crankshafts...
    Rubber is in perfect condition, no cracks... seal surface has slight groove, may need a seal sleeve.
    Local pick up ok in California
    https://www.ebay.com/itm/C8ZE-A-HiP…275.c4#viTabs_0
  • Here is an Ebay auction for a used C8ZE replacement Hipo harmonic balancer by Ebay member "jzram" with a Buy-It-Now of $275.00:
    Rubber is in perfect condition, no cracks... seal surface is smooth, no groove...
    https://www.ebay.com/itm/C8ZE-A-HiP…m8AAOSwGoRcZKpM
  • Quote from C6ZZKGT
    This used C8ZE replacement Hipo harmonic balancer sold September 5, 2019 on Ebay for $198.99.
    This used C8ZE replacement Hipo harmonic balancer sold November 6, 2019 on Ebay for $198.99.
  • Here is an Ebay auction for a used C8ZE replacement Hipo harmonic balancer by Ebay member "leadfoot_usa" with a Buy-It-Now of $325.00 or make offer:
    289 HiPo Cranskshaft Balancer OEM. Condition is Used.
    This is an OEM crankshaft balancer casting number C8ZE.
    This is a service replacement for the 289 High Performance engine.
    Part number: C8ZE-A.
    Elastomer is slightly split as shown in the picture but still works fine.
    Balancer has Ford markings.
    https://www.ebay.com/itm/289-HiPo-C…m4383.l4275.c10
    https://www.ebay.com/itm/C8ZE-A-HiP…m4383.l4275.c10
  • This Ebay auction for a used C8ZE replacement Hipo harmonic balancer was ended by the seller December 1, 2019 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • Here is an Ebay auction for a used C8ZE replacement Hipo harmonic balancer by Ebay member "fordmanted2b2b" with a Buy-It-Now of $300.00:
    [size=4]RARE 289 HIPO REPLACEMENT C/SHAFT DAMPNER THAT FOMOCO USED TO REPLACE ORIGINAL CUT BACK C5OE DAMPNER. IT DOES SAME JOB W/O COUNTERWEIGHT THAT I AM LISTING SEPARATELY IN OTHER AD. NEED TO USE WITH 289 1" BLOCK AND 1M CRANK ONLY. THIS ONE ISN'T BEAT UP EITHER LIKE SOME LISTED BEFORE. IT WASN'T USED VERY LONG ON ENGINE DUE TO ROD THROWN BY OVER REVING. REASON IT STILL LOOKS NEW. RUBBER SEAL IN GOOD SHAPE. VERY HEAVY COMPARED TO STOCK ONE.THANKS FOR LOOKING TAKE CARE AND GOD BLESS fordmanted2b2b [/size]
    [size=4] PRICE DROPPED FROM $350 TO $300 DUE TO GIFT SEASON. SURPRISE SOME ONE. MERRY CHRISTMAS POSTED ONE POUND UNTIL LOCATION KNOWN. [/size]
    [size=2]https://www.ebay.com/itm/RARE-65-67…C0AAOSwRWZcHzvj[/size]
    This used C8ZE replacement Hipo harmonic balancer sold December 18, 2019 on Ebay for $189.99.
  • Here is an Ebay auction for a used C8ZE replacement Hipo harmonic balancer by Ebay member "yellow19700" with a Buy-It-Now of $250.00:
    Ford Mustang C8ZE-A HIPO 289 BOSS 302 Harmonic Balancer Vibration Damper Dampner - OEM Original
    https://www.ebay.com/itm/Ford-Musta…KAAAOSwWNZeBrOV
  • Here is an Ebay auction for a used C8ZE replacement Hipo harmonic balancer by Ebay member "darre_levi" with a Buy-It-Now of $199.00:
    HIPO 289 Harmonic Balancer C8ZE-A Mustang FORD FoMoCo Dampner 0-30 timing. Condition is Used. Shipped with USPS Priority Mail.
    https://www.ebay.com/itm/HIPO-289-H…OoAAOSwmeNeCtGZ
    This Ebay auction for a used C8ZE replacement Hipo harmonic balancer was ended by the seller January 8, 2020 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • This Ebay auction for a used C8ZE replacement Hipo harmonic balancer was ended by the seller January 8, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
    Fred-
    This used C8ZE replacement Hipo harmonic balancer that was no longer available" is back on Ebay again with a much lower Buy-It-Now of $149.00:
    https://www.ebay.com/itm/HIPO-289-H…W0AAOSw~WpeFfWy
    This used C8ZE replacement Hipo harmonic balancer sold January 13, 2020 on Ebay for $149.00.
  • Here is an Ebay auction for a used C8ZE replacement Hipo harmonic balancer by Ebay member "mustangranch18" with a starting bid of $9.00:
    Ford Mustang C8ZE-A HIPO 289 BOSS 302 Harmonic Balancer Damper . Condition is Used. Shipped with Flat Rate Freight.
    https://www.ebay.com/itm/Ford-Musta…VUAAOSwrTFeQ2YR
