• o (1) C3 Casting, 4A14, Tested $1000
    o RARE '67 TE Heads Set Castings, 6M22, Tested, $1800
    o RARE '67 Rebuilt Set Non-TE Heads, 6M8, Rebuilt, Tested $2400
    o RARE '67 Rebuilt Set Non-TE Heads, 6M22 7E8, Tested $2200
    o C8 Set Heads Non-TE 9K23, $1500
    o Used Rods, Floated, $500
    o Used Rods, NOT Floated, SOLD
    o NOS Boss 302 Rods, not numbered, $900
    o Used STD Pistons, $350
    o New Set Sealed Power 4.030" Pistons, $400
    o Used Fans, A67, Like New, $600, G4, $700
    o C5 Distributors FoMoCo, Used $500, Rebuilt $625
    o Motorcraft Distributors, $350
    o NOS Valve Springs (6), $25/each
    o NOS Valve Spring Retainers, $250
    o Used C5 Damper, A5, $500
    o NOS C8 HiPo Damper, $275
    o Original C5AF-10A352-H Alternator Pulley, $125
    o Rare C5AF-10A352-C before 4/1/65, Alternator Pulley, $150
    o NOS Early C3 Timing Set, $425
    (includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight, AND Thrust Plate)
    o NOS Later C5 Timing Set, $325
    (includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight)
    o Reman Aluminum Water Pumps, $400
    o VERY RARE Reman ‘65 Cast Iron Water Pumps, C5OE-B Repro Impeller $425 (used May-August ‘65 only)
    o Reman ‘66-67 Cast Iron Water Pumps, C6OE-A Repro Impeller $325
    o '64.5 Reman/Used Fuel Pumps, 3734-S, $425/325
    Pictures upon request. Prices do not include shipping from VA. I will combine shipping in the case of multiple purchases. Thank you
    Edited once, last by marv (July 24, 2019 at 7:45 PM).
  • Sent you a private message Marv. Thanks.
    Jeff Horsman
    1967 K code Fastback four speed
    1966 Buick Gran Sport four speed
    1986 Buick T-type
    1978 Jeep Wagoneer
