NOS C3OZ 6250 C Hipo Camshaft
    • Official Post
    Here is an Ebay auction for an NOS C3OZ 6250 C Hipo camshaft by Ebay member "shelbym350" with a starting bid of $400.00:
    I have for sale an NOS Ford 289 HIPO camshaft. C3OZ-6250-A. Journals had some surface rust with discoloration but no harm. Comes in Ford camshaft replacement tube. See photos. Measurements are correct.
    https://www.ebay.com/itm/NOS-289-HI…aYAAOSwmetcnAKd
    • Official Post
    The part number that the seller states is incorrect and the Ford box is a C8SZ 6250 A which is for a standard 429 and 460 camshaft. The actual part does appear to be correct.
    • Official Post
    This NOS C3OZ 6250 C Hipo camshaft received no bids by April 1, 2019 and therefore did NOT sell.
    • Official Post
    This NOS C3OZ 6250 C Hipo camshaft is back on Ebay again with a new lower starting bid of $375.00:
    https://www.ebay.com/itm/2642684573…em=264268457341
    • Official Post
    This NOS C3OZ 6250 C Hipo camshaft received no bids by April 8, 2019 and therefore did NOT sell.
  • Here is an Ebay auction for an NOS C3OZ 6250 C Hipo camshaft by Ebay member "shelbym350" with a starting bid of $400.00:
    This NOS C3OZ 6250 C Hipo camshaft is back on Ebay again with no changes:
    https://www.ebay.com/itm/264283096590?Vi...4283096590
  • This NOS C3OZ 6250 C Hipo camshaft received no bids by April 19, 2019 and therefore did NOT sell.
    This NOS C3OZ 6250 C Hipo camshaft is back on Ebay again with a new higher Buy-It-Now of $400.00 or make offer:
    https://www.ebay.com/itm/2642907213…em=264290721309
    • Official Post
    Here is an Ebay auction for an NOS C3OZ 6250 C Hipo camshaft by Ebay member "kcode_1966" with a Buy-It-Now of $750.00:
    Available is a NOS Ford Hipo 289 solid lifter camshaft correct for 1964-1967 high performance 289 engines. Still in the original tube from Ford. Ford part number is C3OZ-6250-C.
    https://www.ebay.com/itm/NOS-1964-1…hIAAOSwmcNdD6pQ
    This NOS C3OZ 6250 C Hipo camshaft was ended by the seller August 9, 2019 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • Quote from C6ZZKGT
    [size=4]Available is a NOS Ford Hipo 289 solid lifter camshaft correct for 1964-1967 high performance 289 engines. Still in the original tube from Ford. Ford part number is C3OZ-6250-C.[/size]
    [size=2]https://www.ebay.com/itm/NOS-1964-1…hIAAOSwmcNdD6pQ[/size]
    This NOS C3OZ 6250 C Hipo camshaft sold August 14, 2019 on Ebay for $750.00.
  • Here is an Ebay auction for an NOS C3OZ 6250 C Hipo camshaft by Ebay member "welbury3028" with a Buy-It-Now of $650.00:
    NOS Mustang 1965 289 Hi Po C30Z-6250-C Camshaft.
    Box is worn!
    https://www.ebay.com/itm/NOS-Mustan…:i:174056838445
  • This NOS C3OZ 6250 C Hipo camshaft sold January 19, 2020 on Ebay for $650.00.
  • This same C3OZ 6250 C Hipo camshaft was apparently determined to be used in an OEM box so it is back on Ebay again as a used camshaft with a much lower Buy-It-Now of $300.00 or make offer:
    OEM USED Mustang 1965 289 Hi Po C30Z-6250-C Camshaft.
    Box is worn!
    https://www.ebay.com/itm/1741823166…em=174182316637
    • Official Post
    Here is an Ebay auction for an NOS C3OZ 6250 C Hipo camshaft by Ebay member "nevadawater4u" with a Buy-It-Now of $750.00:
    Genuine NOS Ford 1965 66 67 SHELBY GT350 & HP K Code MUSTANGS
    Brand New Never Installed. New Old Stock.
    1963-64 HP FAIRLANE CAMSHAFT
    Mechanical camshaft with solid lifters.
    Part # C3OZ-6250-C
    Has all correct ID markings as it should including the FoMoCo stamp. See detailed pictures.
    Still has the protective shipping grease on it in excellent new condition. In it’s original Ford tube although it is tattered some.
    Specs on these camshafts were:
    Duration at 310 degrees intake & exhaust.
    Lift at 0.298” lobe and 0.460” valve.
    Overlap at 82 degrees.
    Shipping insured with signature delivery confirmation.
    https://www.ebay.com/itm/NOS-FORD-1…ery!91387!US!-1
  • This NOS C3OZ 6250 C Hipo camshaft sold April 16, 2020 on Ebay for $750.00.
  • This OEM USED Mustang 1965 289 Hi Po C30Z-6250-C Camshaft sold August 16, 2020 on Ebay for $300.00.
  • Here is another Ebay auction for a used C3OZ 6250 C Hipo camshaft by Ebay member "welbury3028" with a Buy-It-Now of $300.00:
    Box is worn!
    https://www.ebay.com/itm/1743972823…em=174397282352
  • This sure does appear to be the same exact camshaft as the previous auction to me. Maybe the buyer had done a Buy-It-Now not realizing that this camshaft was actually a used one so the seller put it back on Ebay right away.
  • Here is an Ebay auction for an NOS C3OZ 6250 C Hipo camshaft by Ebay member "mortcoil " with a Buy-It-Now of $750.00:
    NOS FORD 1965 1966 1967 MUSTANG SHELBY 271HP HIPO HI-PO CAM CAMSHAFT K-CODE.
    C3OE-6250-C
    Examine pictures closely and ask questions before bidding. Comes with factory Ford tube. See all Ford marking present can be seen in pictures.
    Sold AS-IS and all sales are final.
    Shipping with in the lower 48 states or Canada only.
    Absolutely NO guarantee or warranty either expressed or implied.
    https://www.ebay.com/itm/NOS-FORD-1…1.c100167.m2940
