HEH-BX Transmission
  • Here is an Ebay auction for a rebuilt HEH-BX transmission by Ebay member "blimpie50" with a Buy-It-Now of $2,499.99:
    This auction is for a Fully Rebuilt 1966 FORD MUSTANG OR SHELBY GT350 289 HIPO CLOSE RATIO TOPLOADER 4 SPEED TOPLOADER TRANSMISSION THIS IS A NUBMERS CORRECT HEH-BX UNIT WITH THE PROPER HIGH LETTERED C5AR CASE (DATED A12 - JANUARY 12 1966), C4ZR TAILHOUSING AND ORIGINAL BEARING RETAINER. THIS IS PROPER AND NUMBERS CORRECT FOR 1966 MUSTANG 289 AND 289 HIPO APPLICATIONS THAT CALL FOR THE "CLOSE" RATIO TOPLOADER. This will fit all 1965 - 1973 Mustang models with the 260 289 302 Boss 302 351C 351W Engine but is numbers correct specifically for the above. It was totally disassembled and professionally rebuilt with all new bearings, brass synchronizer rings, rebuilt synchronizer assemblies, new input, new 2nd and 3rd gears, new output shaft and new seals and gaskets. It comes with a 90 day guarantee ( exclusive of racing applications). It is ready to install in your Mustang! This will be shipped in a specialized reusable shipping crate designed for toploaders and requires a $200 refundable deposit. Purchaser to pay shipping based on 135 pounds from zipcode 08520 and the $200 crate deposit ( the crate deposit is refundable as soon as the crate is returned to us). Feel free to ask any questions.
    https://www.ebay.com/itm/1966-FORD-…=p2047675.l2557
    This rebuilt transmission sold January 23, 2019 on Ebay for $2,499.99.
  • Here is an Ebay auction for a rebuilt HEH-BX transmission by Ebay member "blimpie50" with a Buy-It-Now of $2,799.99:
    This auction is for a rebuilt CLOSE RATIO 4 Speed Toploader Transmission for a 1966 FORD MUSTANG 289 HIPO or SHELBY GT350. This is an original Ford unit with the proper low lettered C5AR Case, Correct C4ZR Tailhousing for Mustang applications (without the hump, proper for the HEH-BX), Original Input Bearing Retainer and HEH-BX Tag. This is fully rebuilt with a New Input Shaft, New 2nd Gear, New 3rd Gear, New 1-2 Synchronizer, Rebuilt 3-4 Synchronizer, New input and out bearings, New brass synchronizer rings, New needle bearings, Matching "B" February Date codes on the tail and case as shown, New input and output shaft seals and all New gaskets. This original Close Ratio Toploader is ready to install and great for anyone's correct restoration. This will also fit all 1965 - 1973 MUSTANGS with the 260 289 302 BOSS 302 351W or 351C V8's but is numbers correct specifically for 1966 K CODE APPLICATIONS. [/size][size=5]The original case is in great shape, no repairs. Our transmissions ship in premade shipping containers which require a $200 crate deposit which is refunded upon its return (we schedule the call tag and pay return shipping to make it easiest). It is also available for inspection and pickup at our Central New Jersey shop location. When purchasing it is easiest to call to run the $200 deposit on a credit card but we can also send a paypal invoice as well. Feel free to ask any questions.
    https://www.ebay.com/itm/1965-1966-…RkAAOSw-7ZdhTSz
  • Here is an Ebay auction for a rebuilt HEH-BX transmission by Ebay member "jarsncars" with a Buy-It-Now of $2,450.00:
    1965 Ford close ratio HiPo 4-speed transmission also used in early Shelby. Tag reads HEH BX, I have the receipt for the rebuild from Reed Automotive.
    https://www.ebay.com/itm/1965-FORD-…-EAAOSwWy5eJY9b
    The seller states that this transmission is for a 1965 but it is in fact for the 1966 model year.
    This listing was ended by the seller February 6, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This rebuilt HEH-BX transmission sold February 20, 2020 on Ebay for $2,450.00.
  • Here is an Ebay auction for a rebuilt HEH-BX transmission by Ebay member "bleedfordblue69 " with a Buy-It-Now of $1,999.11:
    REAL McCOY, 1966 MUSTANG 289 HI-PO CLOSE RATIO TOP LOADER 4 SPEED. REAL TAG AND NOT A REPLACEMENT. COMPLETELY REBUILT WITH NEW, INPUT, BEARING RETAINER, 1ST, 2ND, 3RD, CLUSTER GEAR, 1-2 SLIDER, 3-4 SLIDER, BEARINGS, BUSHING, SYNCRO'S, AND SEALS. ALL PARTS BOUGHT THRU DAVID KEE. CASE GREAT WITH NO REPAIRS OR CRACKS. TAIL SHAFT NOT WORN OUT. DOUBLE REAR SEALS. NEW SHIFTER LINKAGE. ORIGINAL SHIFTER STILL MOSTLY TIGHT. HANDLE POOR AND REVERSE LOCK OUT STUCK IN UP POSITION WITH HALF OF LEVER BROKEN. NEW HANDLES CAN BE ACQUIRED. SHIPPING AND BOXING FEE WILL BE $200 TO 48 STATES. IF YOU LIVE NEAR A MAJOR CITY, I HAVE A FRIEND THAT DELIVERS MOTORCYCLES AROUND THE COUNTRY AND IF YOU ARE NOT TOO FAR OFF A MAJOR INTERSTATE CAN MEET YOU AT A TRUCK STOP FOR GAS MONEY. PLEASE CONTACT ME FOR A QUOTE. ALL QUESTIONS WELCOME.
    https://www.ebay.com/itm/1966-Ford-…w4AAOSwB~Bfi4px
    This rebuilt HEH-BX transmission sold October 19, 2020 on Ebay for $1,999.11.
  • Here is an Ebay auction for an HEH-BX transmission by Ebay member "kevinmanley2011" with a Buy-It-Now of $2,500.00 or make offer:
    1966 FORD MUSTANG/SHELBY GT350 289 HIPO CLOSE RATIO TOPLOADER 4 SPEED Transmission. Item is new condition with some scratches from storage. See pictures for more details
    1966 FORD MUSTANG/SHELBY GT350 289 HIPO CLOSE RATIO TOPLOADER 4 SPEED Transmissi | eBay
    The sellers description states that transmission is new but it has a VIN stamp for a 66 Fairlane with a 289 on it.
  • This rebuilt HEH-BX transmission sold July 11, 2023 on Ebay for $2,500.00.
  • Here is an Ebay auction for a rebuilt HEH-BX transmission by Ebay member "blimpie50" with a Buy-It-Now of $3,299.99:
    THIS AUCTION IS FOR A FULLY REBUILT ORIGINAL 1966 FORD MUSTANG 289 HIGH PERFORMANCE K CODE OR 1966 SHELBY GT-350 TOPLOADER 4 SPEED TRANSMISSION. THIS IS AN ORIGINAL CORE THAT WAS FULLY REBUILT WITH NEW SECOND AND THIRD GEARS INSTALLED AS WELL AS A NEW 1-2 SYNCHRONIZER.. THIS WAS FULLY DISASSEMBLED WITH NEW BEATINGS, SEALS, SYNCHRONIZER BLOCKING RINGS INSTALLED THIS IS THE ORIGINAL C5AR HIGH LETTER CASE (CORRECT FOR 1966) WITH MATCHING ORIGINAL C4ZR NON HUMPED TAILHOUSING (ALSO CORRECT FOR THIS TRANSMISSION). THIS HAS THE ORIGINAL HEH-BX TAG ON IT STILL. THIS IS THE FACTORY "CLOSE RATIO" UNIT COMMONLY USED IN THE K CODE MODELS AND LATER GT-350'S WITH THE TOPLOADER.. THIS IS A FULLY NUMBERS CORRECT REBUILT AND READY TO GO TRANSMISSION. EVEN THE BEARING RETAINER IS AN ORIGINAL WITH CORRECT NUMBERS. OUR TOPLOADERS SHIP IN A PREMADE CASE THAT REQUIRE A $200 CRATE DEPOSIT THAT IS REFUNDED UPON ITS RETURN (WE PAY THE RETURN SHIPPING AND ISSUE A CALL TAG ON OUR END TO STREAMLINE ITS RETURN). LOCATED IN CENTRAL NJ (HIGHTSTOWN) FOR LOCAL PICKUP OR INSPECTION OR CAN BE SHIPPED SEE THE SHIPPING COST CALCULATOR FOR A QUOTE ON SHIPPING COSTS.
    1966 FORD MUSTANG 289 HIPO OR SHELBY GT-350 TOPLOADER TRANSMISSION HEH-BX REBUIL | eBay
  • Here is an Ebay auction for an HEH-BX transmission by Ebay member "darkcloud767" with a Buy-It-Now of $2,500.00:
    This is a rebuilt 1965-66 Ford Mustang Hipo HEH-BX Toploader Transmission, perfect for vintage car enthusiasts. It fits specific Ford models and has undergone refurbishment to ensure smooth and efficient performance. The manufacturer part number is HEH-BX. This transmission is not a universal fitment and is not intended for use as a performance part. It is a vintage part that has been restored to its original condition, ensuring that it will function as intended in your classic Ford Mustang. Don't miss out on the opportunity to add this piece of automotive history to your collection.
    I sell about 2 top loaders per month, they are the ones I look for the most (HEH-T or HEH-BX). Some are stamped with the VIN on the bottom and some on the pad on the bottom. Most were not stamped by Ford.
    I offer a 6-month warranty on my top loaders. If there is a problem with the transmission, ship the item back to me and I will fix the problem and ship it back to you. I have never had one sent back to me which should give you some ease, but we are all human and mistakes happen.
    These transmissions are super tough and should give you many years of trouble-free use. Thanks. -Kevin Manley
    1965-66 Ford Mustang Hipo HEH-BX Toploader Transmission Rebuilt | eBay
    This transmission has no VIN stamp and has a reproduction transmission tag. Please draw your own conclusions on this.
  • Here is an Ebay auction for an HEH-BX transmission by Ebay member "kevinmanley2011" with a Buy-It-Now:
    This is a freshly rebuilt OEM 65-66 Mustang HIPO transmission. A few of them have the vin stamped either on the pad on the bottom or across the belly which I have had both but the vast majority of them have no vin stamped on them at all just like this one. This is a close ratio top loader and it has the C5 case the C4Z tail shaft. The tail shaft has some tape on there that is the bottom plug because it is too hard to move around with that plug in there. This is concours correct for a 65-66 HIPO car with a 289 in it or a 302 and it is ready to install. We do ship all our tranny's with no oil and the top cover is not sealed. We have a 6 month warranty on the transmission you just have to send it back and we will fix it. We've never had one sent back but its peace of mind. Thanks for looking at my transmission. Kevin Manley Kevin's Klassic Cars
    Ford Top Loader Mustang 65-66 Hipo HEH-BX close ratio | eBay
    This rebuilt HEH-BX transmission sold December 28, 2023 on Ebay for $2,500.00.
    This rebuilt HEH-BX transmission sold April 1, 2024 on Ebay for $2,299.99.
  • Here is an Ebay auction for a rebuilt HEH-BX transmission by Ebay member "uglider" with a Buy-It-Now of $2,700.00:
    Rare HEH BX Toploader Close Ratio 289 Hipo 4 Speed Transmission remanufactured by David Kee Top loaders with new bearings, synchronizers, seals, vent added and new 2nd and 3rd gears. Includes New Hurst Competition Shifter with reverse light switch. Installed and tested with less than 20 miles run time. Shifts in all gears as new.
    Ford Top Loader HEH BX 65-66 289 & 289 Hipo Mustang 28 spline Close Ratio | eBay
