Used Disc Brake Caliper Bracket
  • Here is an Ebay auction for a pair of used disc brake caliper brackets by Ebay member "magmustangs" with a Buy-It-Now of $199.00:
    1965-1967 Ford Mustang, Fastback, Coupe, Convertible, GT, GTA, Shelby GT-350, GT-500, Mercury Cougar, GT, 6.5 Litre, XR7.. LH+RH Front Disc Brake Caliper To Spindle Mounting Brackets. For the Early 4-Piston Disc Brake Calipers. .. These are ORIGINAL FORD PARTS. Removed from a 66 Mustang GT with Factory Disc Brakes. Have K/H 54313-RH and K/H 54314-LH casting numbers. The Caliper Brackets are in Great Condition. No heavy Rust or metal pitting. No cracks or fractures. They are factory straight. Not bent or warped. All of the threads seem good. Overall, this is a Great Pair of Original LH+RH Disc Brake Caliper Brackets...
    https://www.ebay.com/itm/16321…?ssPageName=STRK:MEWAX:IT
  • Here is an Ebay auction for a pair of used disc brake caliper brackets by Ebay member "papajoe5557" with a Buy-It-Now of $199.99 or make offer:
    [size=4]VINTAGE 1965 66 MUSTANG SHELBY GT350 KELSEY HAYES FRONT CALIPER MOUNTS 289 HIPO K CODE ORIGINAL OEM PARTS[/size]
    [size=2]https://www.ebay.com/itm/1965-…b5e451:g:3OUAAOSw8VhdbbCi[/size]
  • Here is an Ebay auction for a pair of used disc brake caliper brackets by Ebay member "magmustangs" with a Buy-It-Now of $219.00:
    1965-1967 Ford Mustang, Fastback, Coupe, Convertible, GT, GTA, Shelby GT-350, GT-500, Mercury Cougar, GT, 6.5 Litre, XR7.. LH+RH Front Disc Brake Caliper To Spindle Mounting Brackets With Spindle Bolts, Washers and Nuts. For the Early 4-Piston Disc Brake Calipers. .. These are ORIGINAL FORD PARTS. Removed from a 67 Mustang GTA with Factory Disc Brakes. Both brackets are cast K/H and [FoMoCo]. The Caliper Brackets are in Great Condition. No heavy Rust or metal pitting. No cracks or fractures. They are factory straight. Not bent or warped. All of the threads seem good. The original mounting bolts look excellent. Overall, this is a Great Pair of Original LH+RH Disc Brake Caliper Brackets... Please email with questions. 091318-19 WE HAVE AN EBAY STORE WITH THOUSANDS OF ORIGINAL FORD PARTS... CHECK IT OUT..
    https://www.ebay.com/itm/1965-…id=p2047675.c100037.m2107
  • Here is an Ebay auction for a pair of used disc brake caliper brackets by Ebay member "sold81" with a Buy-It-Now of $161.70:
    [size=4]A526 [/size]
    Item comes exactly as pictured. No other parts, hardware, packaging or accessories included.
    https://www.ebay.com/itm/1965-…id=p2047675.c100005.m1851
  • This pair of used disc brake caliper brackets sold November 3, 2019 on Ebay for $161.70.
  • The auction for this pair of used disc brake caliper brackets was ended by the seller January 31, 2020 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • Here is an Ebay auction for a used right hand disc brake caliper bracket by Ebay member "cobranda" with a Buy-It-Now of $80.00:
    BRANDA PERFORMANCE INC.
    SHELBY & MUSTANG PARTS
    *** PRESENTS ***
    1965 - 1967 MUSTANG
    (ALL MODELS & ALL BODIES) DISC BRAKES
    1965 - 1967 SHELBY GT350
    1967 MERCURY COUGAR
    ORIGINAL / USED
    KELSEY HAYES RIGHT FRONT DISC BRAKE
    CALIPER MOUNTING BRACKET
    1-SIDE
    A VERY NICE ORIGINAL / USED & VERY USABLE FORD
    BRACKET: 65-67 MUSTANG & SHELBY GT350 KELSEY
    HAYES RIGHT FRONT DISC BRAKE CALIPER MOUNTING
    BRACKET
    FORD PART#:
    C5ZZ-2B134-B
    SOLD AS 1-PIECE / 1-SIDE ONLY
    RIGHT SIDE
    MADE by KELSEY HAYES for FORD MOTOR COMPANY
    MADE of STEEL w/. a NATURAL FINISH
    THIS 1 ORIG. FORD/KELSEY HAYES: MUSTANG & SHELBY
    RIGHT FRONT MOUNTING BRACKET, has the #4, &
    FOMOCO BLOCK LOGO, & KH, CAST into the STEEL
    ...see pics!!!
    THIS ORIG. FORD/KELSEY HAYES RH FRONT BRACKET,
    includes:
    4 MOUNTING STUDS
    1 BLEEDING STUD
    ...see pics!!!
    A NICE RESTORATION & REPLACEMENT ORIG. FORD:
    65-67 MUSTANG & SHELBY GT350 KELSEY HAYES
    RH FRONT DISC BRAKE CALIPER MOUNTING BRACKET
    THIS 1 ORIG. FORD/KELSEY HAYES BRACKET: 65-67 MUSTANG & SHELBY KELSEY HAYES RIGHT
    FRONT DISC BRAKE CALIPER MOUNTING BRACKET PICTURED, IS the 1 ORIG. FORD - KELSEY HAYES
    RIGHT FRONT MOUNTING BRACKET you WILL RECEIVE
    https://www.ebay.com/itm/1965-…:i2AAAOSw27Zeqcu7&vxp=mtr
  • Here is an Ebay auction for a pair of used 65/66 disc brake caliper brackets by Ebay member "cobranda" with a Buy-It-Now of $165.66:
    BRANDA PERFORMANCE
    *** PRESENTS ***
    1965 - 1966 MUSTANG
    (FITS ALL MODELS & ALL BODIES) V8 & DISC BRAKES
    1965 - 1966 SHELBY GT350 & GT350H
    ORIGINAL / USED
    KELSEY HAYES FRONT DISC BRAKE CALIPER
    MOUNTING BRACKETS
    1-PAIR
    VERY NICE ORIGINAL / USED & VERY USABLE FORD /
    KELSEY HAYES BRACKETS: 65-66 MUSTANG & SHELBY
    KELSEY HAYES FRONT DISC BRAKE CALIPER MOUNTING
    BRACKETS
    KELSEY HAYES PART#'s:
    54313-RH
    54313-LH
    SOLD AS 1-PAIR of BRACKETS
    LEFT & RIGHT SIDES
    EACH MADE of CAST STEEL
    RECENTLY:
    CLEANED / DIPPED / & LIGHTLY BLASTED
    NATURAL FINISHES
    READY for COATING or PAINT
    EACH ORIG. BRACKET, has K/H & a PART#
    CAST into the FRONT EDGES
    ...see pics!!!
    NO SPLITS / NO CRACKS
    EACH BRACKET is SOLID / CLEAN
    THESE 1-PAIR of KELSEY HAYES BRACKETS, DO
    NOT INCLUDE MOUNTING HARDWARE
    THESE ORIG. FORD - KELSEY HAYES BRACKETS, CAME
    out of a WEST - UTAH: NOS, ORIG., & NEW-REPRO.:
    MUSTANG & SHELBY PARTS LOT
    CONCOURS RESTORATION ORIG. FORD / KELSEY HAYES:
    65-66 MUSTANG & SHELBY GT350 FRONT KELSEY HAYES
    DISC BRAKE CALIPER MOUNTING BRACKETS
    THESE ORIG. FORD - KELSEY HAYES BRACKETS: 65-66 MUSTANG & SHELBY GT350
    FRONT KELSEY HAYES DISC BRAKE CALIPER MOUNTING BRACKETS PICTURED,
    ARE the ORIG. FORD - KELSEY HAYES FRONT BRAKE CALIPER MOUNTING BRACKETS
    you WILL RECEIVE
    *** GENUINE ORIG./USED FORD: 65-66 MUSTANG & SHELBY
    GT350 FRONT KELSEY HAYES DISC BRAKE CALIPER
    MOUNTING BRACKETS!!!***
    *** A BUY IT NOW AUCTION!!!***
    https://www.ebay.com/itm/1965-…=p2385738.m4383.l4275.c10
  • This pair of used disc brake caliper brackets sold July 27, 2020 on Ebay for $199.00.
  • This pair of used disc brake caliper brackets sold July 31, 2020 on Ebay for $199.99.
