• Sold for final sale price by seller OrlandoMustang1966
    Osteen, FL
    1966 Ford Mustang K-GT Conv 289 Hi-Po 66 K Code
    Options: 289 K Engine Serial # is Stamped on Block and Matches Inner Fenders, 4 Speed, "Working" AM-8 Track, Rally-Pac, Deluxe Pony Interior, 4 Wheel Disc, Dual Master Cylinder, Styled Steel Wheels, No Power Steering
    Interior: All New Interior, Aqua and White Pony Interior, Pony Steering Wheel, New White Power Top, with Folding Glass
    Exterior: Color Changed from White to Turquoise, New Wind shield, Replaced Front Fenders & Rear Quarters. This car recieved a complete restoraiton in 2003. With new paint, chrome, weatherstriping.
    Engine Compartment: Numbers Matching , ENGINE with K Code VIN, Dyno Tuned @ 318hp at the Flywheel, Motorsport Engine Pulleys, Aluminum heads and Performer RPM intake, 600 Holley CARB, Tri-Y Headers (HPC Coated), Replacement Voltage Regulator, Alternator, Air Cleaner, Intake, Fan, Radiator, Orig Limited Slip, 9" Rear, Heavy Duty Steel Flywheel, Blow Proof Bell Housing, Vehicle has correct 289K Distributor, Dual Resevoir Master Cylinder Added
    Mechanical Condition: All New Suspension, 1" Sway Bar, DynaMax Super Turbos Mufflers (2 1/4in), Tri-Y Headers, Rear Stainless Steel Brake Kit, Front End Aligned, Wide Ratio Transmission Installed, Center Force Clutch, drives excellent, dependable, ready to show or cruise.
    Rust History: Car is from California, Original Inner Fender Aprons, Slight Repair Left Hand Drivers Footwell
    Documentation: Florida Title, Restoration Receipts, Matching numbers on inner fender and Door Data Plate, Driven 1,000 miles since restoration, Restoration finished about 2003.
    *Mileage is not confirmed could be 60,986 or 160,986
    eBay link
    Edited once, last by 65gt_old (September 25, 2009 at 4:52 PM).
