Early car, or what's left of it....
Sold for ??? by seller goldenknight89
<BLOCKQUOTE id=quote><font size=1 face="Verdana" id=quote>quote:<hr height=1 noshade id=quote>1964 1965 K Code HIPO Ford Mustang Project or Parts Car
Re-listed. Because I mentioned the tltle in the previously, eBay removed the listing.
VIN 5F07K162XXX. VIN stamped on both inner fenders, no data plate. No engine or transmission. Gas, brake and clutch pedals present. Interior is nearly complete. Rear seats and passenger bucket in good shape, although dirty. Driver side bucket has rips on bottom. Dash is uncut. AM radio included. It has all glass. Front is very solid. The front toe boards have been patched. Sheet metal to repair the following is included. There are a couple small holes and a patch on the passenger inner fender (under battery). The driver side front frame extension (that goes from the front frame to the under the floor) is a little rough. There is a rusted area on the passenger outer rocker. The trunk floors and rear frame rails should be repaired. The rear quarters were skinned and look ok from the outside.
The steering box currently installed does not have a tag on it. I have another one with a HCC AT tag on it I will throw in if you want it. The car currently has a 8 inch rear end in it. I have a housing for a 9 inch that was shortened to fit that I'll throw in for an additional $100 (not for sale outside this auction). It has Magnum 500 wheels and trim rings. Tires are good enough to get you home, but that is about it.
I submitted all paperwork to the state last week and should have the clean paperwork soon.
Comes with:
2 full quarter panels (one was banged around in storage, there are a few scratches with surface rust, but it is useable)
Passenger side front inner apron (new, a little surface rust)
Trunk brace (new)
Trunk floors (new)
front frame rail extension
rear frame rail extensions
full floor (a little banged up, but useable)
full floor patches (surface rust, but useable)
passenger side rocker panel (from parts car)
battery Tray (new)
[Blocked Image: http://i9.ebayimg.com/04/i/000/92/59/4c77_1.JPG]
[Blocked Image: http://i17.ebayimg.com/07/i/000/92/59/5058_1.JPG]
[Blocked Image: http://i22.ebayimg.com/07/i/000/92/59/5f66_1.JPG]
[Blocked Image: http://i13.ebayimg.com/07/i/000/92/59/638d_1.JPG]
[Blocked Image: http://i20.ebayimg.com/05/i/000/92/59/6787_1.JPG]
[Blocked Image: http://i4.ebayimg.com/02/i/000/92/59/5aac_1.JPG]
[Blocked Image: http://i11.ebayimg.com/02/i/000/92/59/6b57_1.JPG]
[Blocked Image: http://i11.ebayimg.com/03/i/000/92/59/55a4_1.JPG]
