• Sold for ?? by seller
    Quote
    This item is the rare 1965-1967 289 hipo K code/Shelby main caps. The main caps have the correct casting numbers such as the C30E-A, the second cap has the #1 with the arrow and a cast in dot, #2 with an arrow and the cast in A, #3 with the arrow and the fourth main cap has an arrow yet the #4 is not visible and there is a ground off section...see photo. All of the main caps fit perfectly on the original K code block which was date coded 7D4 (April 1967). The block was .060 over and damaged. Prior to sending it to the recycler, I took photos of the main caps on the block.
    link
  • The #4 cap DOES appear to be genuine hipo, but I bet it started out life as a 1, 2, or 3. They probably ground off the number so there wouldn't be any confusion for future rebuilders.
  • Quote from toolbox
    You can see the #4 inscribed into the ground off area and can see where the original number was removed. Definitely a hipo cap but most likely not an original #4. At least the seller is out front about it...
