Dave, I'm going to take a stab at this: I don't believe there is an actual adjustment on the manual choke.
You need to install the cable so that when the knob is pushed all the way in that the choke butterfly is completely open, and when you pull the knob all the way out the butterfly needs to be completely closed, so you can have full range of movement when you start the engine, espessely in your cold climate......
