May 19, 2008 at 11:46 PM #1 Hello all I've got a question about the Shock Tower/Spring shield bolts for 67' Dearborn Kar. Do the bolts go from the outside in or inside out?I've been told it could be both.Thanks Q
May 20, 2008 at 12:15 AM #2 It could be either. Check the "footprint" left in the metal from the bolts. Should tell you which way they were originally.
May 20, 2008 at 6:53 AM #3 As Charles said it can be either but they should all be installed in the same direction.
May 20, 2008 at 7:00 AM #4 Thanks for the info. The Footprint looks like they went in from the outside.
