January 14, 2007 at 10:59 PM #1 What has to be removed so the pan will slide out after the pan bolts are removed?Thanks,GaryEdited by - SixT5HiPo on 01/15/2007 17:05:15
January 14, 2007 at 11:24 PM #2 The cross brace has to be removed, the starter and then just unbolt the idler arm from the frame and it will allow you enough room to wiggle the pan out.
