air cleaner base color
  • CSX is that the same formula as the PPG tag as it's base/clear application and your motor parts that are gold have a shine so I'm assuming that is the same paint deal or is it?...Oh by the way caspian65...THANKS!
  • RPM,
    That is the same formula. I did not use PPG. Dupont Centari is what I used with the hardner. The paint store will cross numbers to make the formula. I use a hardner in the paint to with stand the heat from the engine. The hardner does give a nice shine. No clear coat was used. When I restored Gene's base I saved the original paint chip's to compare and it was a perfect match. Make sure you use a self etching primer on the bare metal parts. You can get that in a spray can. Little expensive but worth it. Pint size is enough to do air cleaner and valve covers for standard 289.
    Dave V.
