67 Shelby and Mustang Parts list
Original 10 spoke wheel restored $800
New Goodyear Speedway 350 Tires $1200/4
Restored rust free disc brake spindles $275
Restored plated correctly brake calipers $500
Metallic brake pads $50 set
Restored PS Pump for GT350 or GT500 with AC – W/new large pulley $500
NOS Caliper rebuild kits, pistons, seals, transfer tubes, bleeders screws $150
Restored Strut Rods – rust free desert parts $225
Restored 428 Flywheel C6AE $450
Restored upper control arms, rust free parts , correct riveted ball joints $1000 pr.
Restored Tie Rod ends, no grease zerk originals with correct straight adjuster sleeves $500
Restored coil spring seats $300 pr.
Rust free 67 radiator brackets w original pads for large radiator $100 set
Restored Disc Brake Booster $350
Restored 67-69 Disc brake master cylinder – correct bendix $300
67 PB Pedal assembly for automatic $175
Restored disc brake booster $300
Restored 9 inch bare axle tube with large fill plug $950
Restored 28 spline axles w/new USA premium Timken bearings $350
Rebuilt 28 spline posi 3rd member 389 gears . restored ready to drop in $1100
Restored rear brake drums $500 pr.
Segmented metallic brake shoes $225 set
Restored concourse 31 spline 4 speed driveshaft with correct slip yolk $950
Complete 67 GT500 Drum to drum SPEC nodular 31 3.50 trac lock spline detailed, ready to install with all correct restored original parts $6,000
67 Rust free 9 inch rebound bracket with correct C3 bumper $350
Concours dual exhaust double hump resonator pipes $1000 pr.
Fomoco script exhaust clamps $25 each
GT500 Cast iron Crankshaft pulley – restored $250
GT500 harmonic Balancer – new SFI approved reproduction $225 with correct attached pulley
GT500 Dual Point dist – restored ready to drop in 66 date $500
GT500 Induction complete! All new parts , including C7ZX intake, BJ/BK Holley Carbs, Cobra Dual quad air cleaner and element. Ready to bolt on with all correct tall heater fitting, water temp sender, fuel log, dual quad linkage, mounting bolts, gaskets, fasteners $2500
GT350 lemans carb , new $750
Restored GT350 Cobra Intake manifold very rare S7MS part number , very nice original casting , complete with correct heater fitting. Water sender $1200
Cobra Intake S7MS parts number – has had carb plenum milled out then repaired – cant be seen after installed. Has correct S7MS part number but no firing order $450
GT500 Valve covers – brand new limited quantity made to our specs, correct single line sand cast Cobra Lemans; drivers side milled for master cylinder clearance like originals , mirror polished fins and letters like original, not just sanded like other repros. $350 set
Restored GT500 cast iron bellhousing and inspection plate late 66 date code $450
Restored RUG-S 4 speed blueprinted transmission $1995
Restored 67 RUG-N close ratio trans $1895
Restored 67 shifter complete for GT350 , replated control box with all correct rods. Levers, rechromed handle, lower boot, back up switch $800 GT500 $1000
Restored GT500 Fan blade , no fan clutch $150
New Steel Flywheel correct balance $350
67 GT500 with ac complete oil cooler kit . some NOS parts $1250
GT500 Clutch renew kit 1 3/8 10 spline 11 ½-12 inch long pressure plate , Carbon Kevlar Disc , premium throwout bearing $450 deduct $25 for stock type organic disc
GT350 Clutch renew kit 1 1/16 – 10 spline 10 ½ inch $425
New gas tank with drain plug and scripted date code $250
67 Shelby Hood with louvers for air cond. Original nice used $2000
NOS Black fastback plant style headliner – very thick material very little stretch $300
Mint original rear bumperettes with rubbers $30 Pr.
Have about 20-30 more items to add in about two weeks
Exact shipping by UPS
(920) 434 3645 Jesse@shelbyparts.com
