Need the following for 12-64 build date San Jose’ HiPo fastback
FoMoCo coil, HiPo Alt Belt C5OE, Fan Belt C5OZ-8620
Rad Cap. "S.M.CO. PAT. NO. 2.582.209", chrome rivet, reads "Tighten" and "Remove Slowly".
Original Front bumper, no date stamp or must end in a “4”
FoMoCo Voltage Regulator, Black, C5AF
Black seat backs with vertical ribs (have near perfect seat covers now) NOS carpet
Rear Axle brake kit, single crimp version with correct stamping on bracket & C5ZZ part # (2282-D?) including rear brake line. Also need single crimp front disk brake hoses.
C5ZZ-2454-A before 3/65 disc brake pedal pad (no provision for trim ring)
Group 24 Yellow Script / yellow Caps Battery, standard posts, any condition.
Pair “Flat Top” hood bumpers. NOS Front window “runners” with clear plastic C522652-1538A & 39A) <left & right>
Gas Tank Sending unit, C5ZZ-9275-A prefix with C4ZF eng #.
C5ZZ-6513208-A “Black label” sill plates –square cut
C5ZZ- 6520588-A 89-A door end seals
Rear Axle tag C5ZA-B, 3L89 4 (month J,K, or L)(week a-d) SP
Cowl seal - C5ZZ-16740-A
Dimmer switch, real round on the top, C1TZ
Mike 516-356-2319
