i have a real nice early 64.5 mustang wide ratio top loader 25 spline output shaft with yoke, the tag is missing, second gear has 31 teeth which confirm it as a wide ratio, casting numbers on main case are C4AR-7008-A W-2 date code F 28 4, tail shaft casting numbers are C4DR-7A040A, date code F 26 4, trans has never been apart gears still have original paint daubs, all internals look very nice, i would install this trans and run it just as it is. $800.00,or reasonable offer. contact jjz109@msn.com, for pictures and info , trans can be picked up at ford Carlisle this June.
