Great running SB Ford 221 CID engine
  • I have available a Great Running original Small Block Ford 221 cubic inch long block motor for sale. $650 or best reasonable offer. Freshly rebuilt heads and new platinum spark plugs. The engine runs really smooth, and cool, doesn't leak, or burn oil. It comes with valve covers, oil pan, timing cover. You'll need a 2 barrel intake and carb and oil dip stick and tube. The intake and carb went on a 289 motor. I also have the water pump I took off during removal but you should replace it with a new one, they're cheap. The heads were rebuilt completely and have the larger 289 size valves so it breathes better. This engine was originally produced for the 1962/63 Fairlane and Meteor but can be used in a Falcon or Comet or 64 Mustang. It is a 5 bolt block. This is a strong running engine. The lower half was professionally rebuilt about 25K miles ago with quality parts. I will deliver the engine within 100 mile radius for $50. You'll need a lift on your end. I was using the engine in another car while I was rebuilding my 289. I drove a car with this motor from Virginia to Florida in November 2006 without any problems. It's a reliable motor that just goes and goes. When I bought the motor it had 302 heads with larger power robbing combustion chambers. I replaced the heads in May 2007 with heads designed for this engine which improved performance significantly. I still have a good set of 1973 302 heads D3OE complete with rocker arms and pushrods available for a $100.
    Respond with Email or call me at 772-539-7935. Lv MSG.
