Available AFTER June 17, 2007. Can be seen on the Kar running and driving up until then. Will be at Milan, Michigan NMRA Car Show June 16 & 17.
Complete Tri Power Set Up, orignal Buddy Bar casting, original air cleaner assy.
Carbs are genuine FoMoCo issue Holley 2bbl. BUT: (please read closely). They are not the proper List Numbers for a 289 Tri Power set up. The middle carb is from a 390 Tri Power and the outer 2 are from a 260 Tri Power. I have located a proper center carb, and the person is willing to trade the 390 carb & a some cash for the proper one.
I have not bothered as the set up works flawlessly as is on a stock 289 K engine. I spent many weeks and multiple carb on/off afternoons jetting and tuning. It is now dialed in perfected. Great MPG on the highway with the center carb also. Custom fabricated choke linkage to allow use of factory manual cable in the proper position.
This set up was completely bench detailed prior to installing in the engine. Carbs HAVE NOT been replated, but still look great.
If a Mustang owner buys this, the Monte Carlo Brace and Fuel Line from the pump will be included. I'll add the Cobra Valve Covers for a small price also.
Asking $1650 + shipping. I know, you can find plenty on ebay for less sometimes. But I guarantee function and driveability of this one. I can even take you for a ride if you'd like in the Kar before it is removed. Most ebay ones will require an added cost of gaskets, jets and repairs from 40+ years of being hacked up by previous owners.
