Wanted: 5 Bolt Block Back Plate Summer 64
  • Wanted: Mint condition block backing plate (between engine block and bell housing) for a five bolt 289 engine dated mid summer 1964 if such a thing exists. The engine for a manual transmission car that I am working on has an aftermarket plate or it is an undated one. In any event it is in poor condition. A rust free dent or damage free one that have never been media blasted or sanded is preferred.
  • Quote from RPM
    They never dated a block plate so you don't have to worry about that one!
    I didn't think so either unit I found these three five bolt ones, two of them have never had more than the worst grease and road grime removed with Gunk® cleaner and a wash rag.
    12 8 61 2
    2 19 64 3
    4 30 63 2
    If they dated things like we do at work these mean:
    December 8, 1961 Second Shift
    February 19, 1964 Third Shift
    April 30, 1963 Second Shift
    The two that are as removed from engines except for washing are cold reduction mill flatten steel without any type of finish except black paint overspray from the engine being painted as an assembly. The one that has been glass beaded has rust pitting except where paint overspray once protected it. These must have been "production" parts as I have gotten some information that some people have some service parts that are painted black all over. The completely black painted ones don't have numbers stamped in them. (I know it is not the same as working for Ford but I work for a very large multinational manufacturing company. We do not date code every part but certain parts that might require field warrantee service are dated IF we use them in production and they go straight to a consumer in our product. The parts designated for product service may be dated but often are not because a lot of the markings on our product only mean something to us in our plant. Our service parts may or may not be just like those used in production or even made by the same supplier. Deductive logic is then I can understand why service parts are sometimes quite different than production parts and the service parts might not always be dated.)
    The car I am working on is one of only roughly thirty with an engine originally of a particular configuration and the details of that configuration are guesses too. The known is they were assembled on or after August 25, 1964 and there was a mix of parts considered 1964 designs and 1965 designs in the same assembly, oil pans for example. Unfortunately since these engines in these cars tended to be highly modified or completely replaced during the last four decades I have not located a car with an unmodified engine I can get access of to examine for fine details of. I am therefore going on deductive logic, which may or may not apply to Ford Motor Company. That logic says if late 1961 through early 1964 production five bolt block plates have a series of numbers stamped into them like date and shift identification then there is a good likelyhood that August 1964 parts might have too. That is not proof I know but dating for an implied four year (1961-62-63-64) period is a trend.
    Edited 2 times, last by rr64_old (October 8, 2008 at 4:26 PM).
