1965 K Fastback Project Needs a New Home
  • I am a motivated seller on this Car. $15,000.00 Or best offer with the motor or 11,000.00 or Best offer With out the motor and Trans.
    Email [email protected] or call 402-529-6337
    This car has been media blasted and had most of the sheet metal work completed. Including, a one piece floor, quarter skins, rear frame rail extensions, frame rails, one piece cowl, firewall, and battery box area. The car still needs to have a very small patch installed on the front fender and the car comes with new door skins, if the new owner wants to install them. The K VIN stampings are on the front fender aprons in 3 places, the hipo rebound plate is there, and the dual exhaust heat shields are in the rear of the floor.
    Included with the car is the interior, with fold down, and large fiberglass rear panels. They have had speaker holes cut in them. All of the interior will need to be restored.
    There is a Hipo motor with the car, heads are fresh and date coded right, the block is date coded correct with Hipo main caps. The engine will need to be machined and assembled. Missing from the engine are the Carburetor, Distributor, and exhaust manifolds. There is a 65 4 speed top loader and bell housing included as well. It is a wide ratio 4 speed.
    The car is a roller now, with disc brakes in the front and 9 inch in the rear. The 9 inch is not the correct Hipo rear, the tubes do not taper. Here is a link to more pictures
    https://cid-99e918b30d826b7a.skydrive.live.com/redir.aspx?pag…=FccmNtVhKJM%24
