can any one tell me what the valve lash on the le mans cam is ?
lemans cam
INTAKE opens 52 deg BTC closes 86 deg ABC
duration 318 deg
EXHAUST opens 82 deg BBC closes 42 deg ATC
duration 304 deg
maximum lift at valve .510" Overlap 94 deg
valve lash: Intake .020" exhaust .025"
Specs below taken at 0.100" tappet lift:
INTAKE opens 6 deg BTC closes 30 deg ABC
EXHAUST opens 40 deg BBC closes 4 deg BTC
Thank you ,I appreciate the info....Buck
