Hey guys, is this PCV connection on my HiPo correct? I’m planning to install a phenolic spacer and someone suggested that the line from the manifold cover should go to a PCV port on the new spacer. If so, what connects to the port on the intake? Thanks.
PCV Connection
Mine goes to the spacer. I have a Ford lettered aluminum intake with a pipe plug in the hole.
So the port on your intake is just plugged?
The content cannot be displayed because you do not have authorisation to view this content. ‘ -
The content cannot be displayed because you do not have authorisation to view this content. ‘ Not sure of what I’m looking at here 🤔.
PCV hose is the one with the remnants of a tag leading to the carb spacer. you can see the pipe plugs in the back of the manifold.
